What are some of the current video medai players that use 3.5" hard drives? What are the advantages of each? In the past, I think I saw a DVD player (DVD disc) that had a removable hard drive in a standard DVD player form factor.
The few models that I've seen reviewed support many different video formats, even HD. But the video quality wasn't very good. For quality, I would look into a standard DVD player, Divx certified, that also has USB support. Then you can simply attach a USB HDD.
Google is your Friend -
These are the better ones out there, you can find them at a lower price if you look around:
http://www.onlybestrated.com/multimedia-centers-high-definition-media-center-c-24_40.html
http://www.onlybestrated.com/multimedia-centers-standard-definition-media-center-c-24_40.html -
I've seen the MediaGate reviewed, don't know about the others. It didn't have very good video quality (SD or HD) and displayed a lot of artifacting.
Western Digital WD6000BLHX 2.5" VelociRaptor Hard Drive Setup
By mn072065 in forum ComputerReplies: 8Last Post: 3rd Dec 2010, 07:14 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 17:18 -
How to connect a 2.5" SATA hard drive ?
By SingSing in forum ComputerReplies: 2Last Post: 2nd Apr 2010, 21:19 -
"capture" from the hard drive
By huaienli in forum Capturing and VCRReplies: 18Last Post: 12th Nov 2007, 14:18
