Results 1 to 26 of 26
    Sep 2003
    Canada
    My new Dell system came with Roxio Creator DE Version: 9.0.116 pre installed. I have Nero 6 from my old system. Which is the better to use? Roxio is just their demo type whereas my Nero 6 is the full version. I am reasonably happy with Nero and unless someone can give me some compelling reasons to switch to Roxio I am just considering removing it all and installing my Nero.
    I use it primarily for burning Home videos and Divx (avi's). I use Wombles video wizard for my editing.
    USA
    I would go with Nero 6, myself. It's still bloatware, but it has it's uses. Don't install InCD, though. As long as you just use Nero for burning, it's a decent program. For encoding or authoring, there are many better programs.
    I would also add ImgBurn to your system. It replaces a lot of Nero burning functions and works better than Nero most times.
  3. Member dadrab's Avatar
    Mar 2006
    State of Denial, U.S.
    I haven't used Nero for anything in a number of years because, in the early days of burning CDs, I tried it several times and created some nice shiney coasters.
    Ever since, I've used Roxio for AUDIO burning only. I only use IMGBurn for video now as Roxio burned me a time or two.
    The long and short of it is, if you do any audio burning, you might want to contemplate hanging on to Roxio for that purpose only.
    In retrospect, I'm sure Nero has gotten better (not knocking it by any means), but I've just chosen to leave it alone as I've found what works for me.
  4. Banned
    Freedonia
    Friends don't let friends use Roxio - EVER.
    While Nero certainly isn't perfect, I wouldn't make that kind of statement about it. Nero is OK for some things (audio CDs and data discs) and it's easy for newbies to use until they are ready to use better programs ImgBurn. Use Nero. It's much better than Roxio.
  5. Roxio is part of crapware comes with Dell. I used Nero burning ROM with zero issue.
  6. I also don't like Roxio, I don't like when things get shoved down your throath.
    Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
    Roxio had a bad reputation for breaking other apps that were installed on the same system with it.
  8. Banned
    Jun 2007
    UNREACHABLE
    Roxio's CD Creator is bad. Nero is less bad, after all.
    But I've been seriously thinking of downgrading it
    from ver. 6.x to 5.x. Versions 6 do not include the
    documentation, you have to download it, and when you
    go read it, you find out it is prettily outdated. Anyway, I have
    already emptied the folders of the other Ahead's applications
    I have never used or will never use again
    (Recoder, Vision Express, InCD, ImageDrive, Cover Editor, etc).
  9. Mod Neophyte redwudz's Avatar
    USA
    I liked Nero 5.5, but it wouldn't work with my newer burners, so I had to update. I have 6.6.0.13 and I won't update that till I have to. And the only part of the package I use is Nero Burning ROM. I'd be happy to just delete the rest of it. But I use ImgBurn mostly now anyway. and Nero only for CD data discs.
  10. Banned
    Jun 2007
    UNREACHABLE
    So go "Ahead"! ^_~
    You won't regret it ^_^
    Now and then I use mkisofs and cdrecord --- just for fun ^_^
    Sep 2003
    Canada
    Can imgburn be used to make DVD data discs ie: divx files?
  12. Mod Neophyte redwudz's Avatar
    USA
    For DVD data files with ImgBurn, use 'Build' mode. Works fine for them.
    Jun 2005
    Vermont
    I use Roxio 8 to capture video from my camcorder in mpeg2 format. I use Womble mpeg video wizard to edit. I use Roxio to burn audio disks & data video disks, all with great success. Not a coaster in the bunch. I've never had very good luck with Nero.
    Sep 2003
    Canada
    Too complicated compared to Nero for this particular task. I use a desktop shortcut to point to Nero Express and I am right there entering files. Imgburn build seems to default to iso for the write mode.
    Nero has never failed me yet on creating data disks that work. One and only time I tried Roxio the files didn't work properly in my dvd.
    Go with what works I guess.
  15. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    How can this
    be more complicated than this:
    /Mats
  16. Bazinga! MJPollard's Avatar
    Nov 2002
    Wixom, Michigan, USA
    Because comparing a screenshot that depicts burning a single ISO file to a screenshot that depicts creating a complex Super Video CD menu is like comparing apples to skyscrapers?
    Don't sweat the petty things, just pet the sweaty things.
  17. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yeah, I know. Thing is, Nero shows the same kind of UI even if you're writing one single data file to disk. So does ImgBurn. My point is, ImgBurn can only seem "complicated" to a hardened Nero user.
    /Mats
  18. Bazinga! MJPollard's Avatar
    Nov 2002
    I know; I just couldn't resist a little good-natured chain-yanking.
  19. nero 7 rocks/ also use dvdflick {free} inconj with imgburn
    Sep 2003
    Canada
    Well this is what I get from my desktop shortcut, not the image posted. When I click on "add", it remembers my last choice taking me to my divx files.
    Not putting down imgburn as I am sure it is much superior to Nero for other tasks
    [/img]
  21. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I actually liked the OLD Roxio Easy CD Creator much better than Nero....and I'd still be using it today (along with another great app called Audiocatalyst) if it would run on XP/SP2.
    Nowadays?....Roxio vs. Nero?
    Simple.... Prassi Ones
  22. Member
    Feb 2004
    Pleasant Hill, CA
    All you have to do it set "Output" to "Device" instead of "Image File". Easy.
    Jim
  23. Member
    Sep 2003
    Canada
    Jim
    Thanks for the heads up Jim!
    By the way anyone else lazy like me who wants to just open Nero Express at the ap in my first post just create a desktop shortcut and use this as the path
    "C:\Program Files\Ahead\Nero\nero.exe" /w /New:ISODisc
  24. Can you show us where did you find the nero command detail ?
  25. Member
    Sep 2003
    Canada
    I found a few spots and experimented until I found switch that worked for me.
    http://club.cdfreaks.com/showthread.php?t=50203
    http://www.google.com/translate?u=http%3A%2F%2Fwww.hackerboard.de%2Farchive%2F10825%2F...&hl=en&ie=UTF8
  26. Member
    Feb 2007
    China
    I've been using Nero 7 for a couple of years now buring DVD movies and KVCDs. NEVER had a problem and that's after couple of hundred burns!! I only use Nero Burning ROM though, tried Express on a couple of CDs and ended up with coasters. I like their Label Maker too. Recode is often compared to DVD Shrink, but it's actually a more powerful tool as it can also create Nero Digital (AVC) files.
    Oh, and if any one cares, NBROM also supports BD and HDDVD.
