ok! i have tried to convert MKV files to DVD using FAVC, I have set up everything and when I hit generate DVD. A error message tab comes up. The tab said "mkvmerge.exe-Unable to Locate Component", and inside the message tab it said. "this application has failed to start because libiconv.dll was not found. Re-installing the application may fix this problem". any help would be great, thnx.
Results 31 to 44 of 44
Did you try re-installing FAVC ?
Which version of FAVC ?
I just use the zipped version, as I already have avisynth installed and setup specifically for my projects. I have never had this issue, however google found 3 references. This was one of them : https://forum.videohelp.com/topic338624.htmlRead my blog here.
guns1inger. thnx for the link. i've use the link and downloaded the file. but then the exact same thing come up, Accept its not "libiconv.dll", its "cygz.dll" so i think i need to get that cygz.dll file right.?
It sounds like you need to re-install FAVC, as something went wrong the first time. These libraries seem to all relate to mkvtoolnix, so maybe you should start by re-installing that.
Read my blog here.
not working... i'mma use one of the other program mention previously or find different program.
Stop downloading mkv files, as you obviously have a problem with them. FAVC is the only thing that seems to work nicely with them, so you need to get it running. That said, sometimes you still get sync problems. I always keep the working files so I can author separately if necessary.
Read my blog here.
Heya gunslinger,
I appreaciate all the advice you have given us and I also have what might amount to newb question about FAVC.
If you use FAVC and have a 1280x720 .MKV file will the output be 1280x720 or will it convert to 720x480?
For everyone having issues with FAVC I had to do the below to get it working.
Install AVISynth 2.57+
Install MKVtoolnix into the FAVC directory
Install ffdshow
Install Haalia Media Splitter
This solved all of the errors I was getting to include missing MKVtoolnix .dll files, avisynth recognition/codec errors.
Hope that helped some. -
Thank for all the help but I got it working with AllToAvi which is much less complicated and remains the subs.
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives!
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 01:45 -
DVD to MKV - MKV to VOB/DVD?
By pavista in forum Video ConversionReplies: 5Last Post: 14th Jun 2009, 07:31
