hello,
not sure if its been discussed before. I searched and did not come up with much.
i have a few video chip that i want to put into a dvd and some data files , like documents and pictures that i can access by browsing the dvd. is it possible?
reason being. i have a presentation and want to show the dvd with the clips in phases, then i want to access the pictures and document later to push the point through.
i know that i can access the PC and show the pic, etc. but at the end of the day. i want to give this material to the audience.
please help! thanks!
Yep. You can put data files in a dvd-video, you just put the files outside the video_ts and audio_ts folder.
What sofware are you using to create/burn the dvd-video? -
i use TMPGEnc DVD Author...
but how do i do it?
i am open to any other kind.... -
Output the DVD to your HDD in TDA and then use the Disc Writing tool to add the DVD content and then add extra files/folder, see the last step in http://www.digital-digest.com/articles/TMPGEnc_DVD_Author_3_DVD_Authoring_Guide_page5.html
Help with documents please
By t_jay17 in forum ComputerReplies: 7Last Post: 9th Feb 2009, 21:37 -
How to display the hidden folder in My Documents?
By coody in forum ComputerReplies: 3Last Post: 9th Dec 2008, 05:40 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 01:52 -
Scan/Archive my documents and invoices using scanner
By ha13may in forum ComputerReplies: 0Last Post: 26th Aug 2007, 16:18 -
searching multiple pdf documents in one folder?
By bballnut in forum ComputerReplies: 6Last Post: 17th Jun 2007, 23:15
