witch one is better. I burnt a movie on 2 cd's. I forgot what settings I put them on.(nero). One movie look's perfect. The other one look's like crap. Why? Could the speed make a diff. in quality? I burn at 4x
click the link to the left that says VCD. you will find the specifications for PAL and NTSC inside there.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
dude im gonna say this in a polite way... stop posting and start reading!!!
i just checked you posts and it seems you have a problem posting this same question repeatedly. if you care at all about this site then please stop poluting it because nobody is bending over backwards to point out whats under your nose.
now ONLY so you will shut up about it and because it is so easy to cut and paste...
PAL
Video:
1150 kbit/sec MPEG-1
352 x 288 pixels
25 frames/second
Audio:
224 kbit/sec MPEG-1 Layer2
NTSC
Video:
352 x 240 pixels
29,97 frames/second
(23,976 frames/second NTSC Film)
Audio:
if you have a file and are converting it you cant just convert NTSC to PAL and vise versa.
if you are capturing from TV you must capture the way the signal is broadcast. if you live in a reigon of the world where they broadcast a PAL signal you need to capture with the correct frame rate and encode it with PAL specifications.
now please look to the left and click some of the subjects and read. the guides and information on this site could not possible be laid out any better. if you cant navigate this site then you have no chance of figuring out VCD's.peace out,
dumwaldo
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
