Hi,
I bought from Aldi the TDVD08 DVD Player. It does play from a 256MB USB Key, but not from a 4GB Key. The 4GB key is brand Exigo. When inserted into the USB slot, it alternates between flashing multiple times rapidly, and one slow. The key works OK on a PC. I have re-formatted the key several times. When attempting to access the key on the player, I get a "cannot do at this time....." message.
Any ideas?
Henry
Australia.
Likewise, same problem, with same light flashing, from a 1GB generic usb drive. Chances are it just likes some and doesn't like others.
"speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
Since my last post I confirmed that the 4GB key works on different PCs and a USB radio. The DVD player reads and SD Card (via an adapter), and a USB Hard Disk. It is definitely a compatability issue. I posted the questions to the distributors, but I doubt if there is a solution.
Henry. -
Are they formatted correctly? Some players will only read FAT32 formatted devices.
Google is your Friend -
Yes, Krispy - FAT32. I don't think they can be formatted as anything else. I formatted the key several times now.
Henry. -
My only other thought would be your USB drivers and/or support (ie. v1 or v2 USB).
LG LH-T751TB USB key issue?
By the shutdown man in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2009, 11:47 -
Philips DVP 5960, compatible USB Key List
By phunkyfish in forum DVD & Blu-ray PlayersReplies: 49Last Post: 30th Sep 2008, 11:18 -
Tevion TDVD08 DVD Player - Picture problem when 5.1 ch setting used
By alfredspacey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Jun 2008, 02:03 -
Region Hack - Tevion TDVD08
By Giosomm in forum DVD & Blu-ray PlayersReplies: 9Last Post: 29th Aug 2007, 08:32 -
Play VOBs from a USB key
By daamon in forum Software PlayingReplies: 6Last Post: 2nd Jun 2007, 04:39
