After my previous problem of cheap blank CDs I have now purchased verbatim blank CDrs.
I am trying to burn a .cue file to create a VCD. I am right clicking on the file and selecting open with toast. This opens toast and recognizes .bin/.cue. I then insert my blank verbatim cd and toast thinks for a while, then ejects the disk and I get the following message:
Please insert a recordable disc
I have an Imac G5 with OSX 10.3.9 and I am using Toast 7 Titanium
Help please!
Results 1 to 10 of 10
Do you insert your disc before or after you click on the Record Disc button at the lower right?
Are you sure the disc is blank? Did you try another one? You said VCD, are you using a CDR or DVD. Should be a CDR for a VCD.
Maybe the bin/cue is too large for a standard CD-R. Many PC users create VCD that are overburned and just don't work correctly.
Blank Blu Ray Discs
By anthonyfellows in forum ComputerReplies: 1Last Post: 10th Dec 2010, 18:46 -
3D DVD Blank Discs
By tealmarlin in forum MediaReplies: 7Last Post: 24th Aug 2009, 18:03 -
Imac won't accept blank DVD-R DL with Toast????
By dunpal in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 18:04 -
Do 20GB Blank Discs Exists?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 18:51 -
which blank discs to use for recording
By Lea Ann in forum Authoring (DVD)Replies: 12Last Post: 2nd Feb 2008, 23:46
