I just converted a small wmv file to DVD using the trial version of convertxtodvd. I wanted to see the quality of the it but when it was finished converting it opened up the burning window. I hit cancel but now I cannot find where the output folder is. I assume it didn't just erase it because I didn't burn it. I checked the program folder in program files, I checked the folder that the original file was in, and I checked the temp directories but could not find it. Any clues?
Any recommendations for WMV to DVD software?
It should be under docs and settings/your username/application data/VSO by default, but you can confirm this by opening ConvertxtoDVD and clicking on Settings -> General and looking at the Working Folder :
You can also turn off automatic burning on the Burning tab.
As for good WMV to DVD software : ConvertXtoDVD is as good as, if not better than anything else. You might look at FAVC and DVD Flick. I like FAVC, and the quality is very good (assuming, of course that the source is very good), but I don't use it for WMV so I don't know how well it handles the format.Read my blog here.
ConvertXToDVD - Help
By Simmons in forum Video ConversionReplies: 1Last Post: 10th May 2011, 01:07 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
ConvertXtoDVD
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 17:19 -
convertxtodvd help
By kennyjunior in forum DVD RippingReplies: 1Last Post: 1st Nov 2007, 12:51 -
ConvertXtoDVD
By gameroftheuk in forum Authoring (DVD)Replies: 3Last Post: 1st Oct 2007, 19:38
