Is there a such thing to just cut rmvb file?
My friend got some crap in this format and she need to cut part of it to fit on disc.
I am allergic to anything "real" so I even had no clue what to look for; our (otherwise good) guides section didn't help either.
Oh and yes I downloaded and installed Real Media Producer 'basic' for her, but![]()
- I couldn't believe it - it can't open .rmvb files (really, LOL).
Results 1 to 11 of 11
Real Media Producer -file-edit real media-new window opens-if that can't load your rmvb file-then the downloaded file is corrupt-download again if you need it
it probably relies on a very old rmeditor,Originally Posted by Baldrick
which you'd have to get from a real installation anyway.
i believe this tool can be safely buried.
yes it can.Originally Posted by DereX888
not always.
i don't know the parameters, or if it automatically equates to a damaged file.
toss it.
gl -
Well guys, first - thx for replies.
I tried REVE (no go at all).
RMP-basic doesn't even have .rmvb filetype in the open files selection. I forced it by selecting "all files" but it doesn't recognize it.
It can produce a new RM file from other few formats, but it doesnt want to opem RMVBs itself
The files certainly are not corrupted - they play from begining to end using real media player and media player classic. Maybe they are "non standard" or something? I dont know how to check it out. Im a totally complete n00b when it comes to "real" shite.
it doesnt open them :/
I can't toss it out.
Its a tv capture of some old stuff from a chinese television that hasnt been ever released on anything anywhere, and it was aired only once on tv.
My friend was downloading it for 2 months (!!! hahaha, what a determination
). I can't do it to her, I might get killed or something
She burnt it on 1DVD + 1CD, but she still wants last episode or two to cut out the end credits so all of it could fit on a single disc.
HELP!
Originally Posted by Midzuki
I could 'convert' it to any other formats using ffdshow filters or (at worse scenario) I could just play it and simultaneously capture the screen to avi, Im a n00b when it comes to RM only
(but thanks for asking).
I am mostly curious now, since she burn it already.
If I only want to 'edit it' (just CUT, aka split) without any reencoding / converting /etc etc, there must be a tool out there capable to do simple cut on stupid "real media" file, right?! -
I suppose only RealProducer Plus can do that :-(If I only want to 'edit it' (just CUT, aka split) without any reencoding / converting /etc etc, there must be a tool out there capable to do simple cut on stupid "real media" file, right?!
{ http://service.real.com/help/library/guides/producer11/RealProducer11.pdf }
If you are playing on media player classic, most probably you have real alternative installed.
If that is so, uninstall both real alternative and real producer basic. Now install real producer basic only. It should work.
I have been editing rm and rmvb files with real producer basic-absolutely no problem. Nothing else has worked well for me.
Had problems long back with real producer basic when i installed real alternative. Uninstalling both and installing real producer alone solved the problem. -
mgh says:
Aa, sou desu ka? Doumo arigatou gozaimashita! ^_^Had problems long back with real producer basic when i installed real alternative. Uninstalling both and installing real producer alone solved the problem.
Toss the project.
if it's that valuable, she should be happy to use 15 disks.
good idea.Originally Posted by mgh
I had the same thought but more as a footnote.
nothing else would.Originally Posted by mgh
with mpc playing the file, i'd say your chances are good:
re-index the file, using rmfix,
or video fixer (payware, not sure of demo policy but it works well).
then load in the realproducer editor.
if it fails,
you're done.
gl
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 17:40 -
find the flash edit tool
By redflower0830 in forum MacReplies: 1Last Post: 1st Sep 2010, 13:22 -
Free Software Tool?
By donkeyking in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 18:02 -
Extract audio and edit from RMVB
By sychern in forum Video ConversionReplies: 1Last Post: 16th Oct 2008, 03:45 -
which software can edit(cut&joint)rmvb?
By ptr866 in forum EditingReplies: 5Last Post: 1st Jun 2008, 11:56
