How can I apply virtual dub filter to a selected portion of my video clip ?
eg. 1 minute video and want to use filter on middle 10 second portion and then save the whole project ?
thanks-
sammywoof
sammywoof
There are only a few filters which can be applied to a specific frame range, like logo,frame tweaker, and may be others.
Depending on the filter you are applying you may have to save your one minute clip as
First 25 min - no filters applied
Next 10 min - filter applied
Last 25 min - no filters applied.
Open all these in VirtualDub again as Appended segments and get your final output.
Sure you must have already thought of the above method as a workaround.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
