    Aug 2007
    Someone knowledgeable with The Film Machine, please give me some insight.
    When i reach the part where it says " Mplex is multiplexing the video and audio stream of file 1 "
    The program ( TFM ) just freezes and when i click on it, it says " THIS PROGRAM IS NOT RESPONDING "...
    I use the New Beta TFM version 1.6.0.6.
    I use CCE v2.70.02.12.
    I have AVisynth 2.5.7 installed
    I have K Lite Mega Codec Pack 3.3 installed.
    Everything is working until i get to the MULTIPLEXING part.
    Then The Film Machine just freezes. And it says " Program is not responding "
    Here is the logg.. I hope you can help me.
    - 8/16/2007 1:15:42 PM
    - AVI to DVD conversion
    - The FilmMachine version 1.6.0.6 beta
    Initializing.
    Computer Info
    CPU name : Intel(R) Pentium(R) 4 CPU 3.00GHz
    Available memory: 1007 MB
    Windows version : Microsoft Windows XP Service Pack 2
    Initializing finished.
    Saving Project File
    DirectX Version = 9.0c
    AC3Filter installed = True
    MPEG Layer-3 Decoder installed = True
    ffdshow Audio Decoder installed = True
    Saving AVI-Info files
    - 8/16/2007 1:15:52 PM
    - Free on drive C: 18.53 GB
    - Audio Conversion with BeSweet and AC3 encoding with Aften
    Executing BeSweet DLL. Commandline:
    -boost( /b2=5 ) -ota( -fs 48000 )
    Converting audiostream 1 of AVI file no 1 of 1
    DirectShow Filters used:
    NullRenderer1
    NullRenderer
    SampleGrabber
    ffDshowFilter
    AVI Splitter
    Avisynth Source Filter
    Audiostream 1 conversion of C:\Documents and Settings\Rob\Desktop\Hot And FLuffy.avi finished.
    Starting CCE 2.70 for getting the CCE title.
    - 8/16/2007 1:19:30 PM
    - Free on drive C: 17.63 GB
    - Video Encoding using Cinema Craft Encoder SP 2.70
    Executing Cinema Craft Encoder.
    TFM_Project_File.ecl found
    TFM_Project_File.ecl encoding started at 1:19:30 PM
    TFM_Project_File.ecl encoded at 1:56:10 PM
    Encoding finished
    - 8/16/2007 1:56:14 PM
    - Free on drive C: 15.25 GB
    - Creating DVD compliant files
    Mplex is multiplexing the video and audio stream of file 1 .....
    Dec 2012
    Baltimore,MD
    Unfortunetly CCE dos not work well with TFM. I would sagjest to use HCenc insted. It dos job as good as CCE BUT it dos not stuck.
    Dec 2012
    Baltimore,MD
    I would also check if there problem with audio encoder. If you installed mega pack with audio encoders then you gona have problems with converting video. Check help in TFM and you'll seeit there.
    CHECK the date when you post. supermannnnn posted 5 years ago....
