Basically I need the equivalent of
the following utilities
VirtualDub
vobsub
Avisynth
that takes as an input file a MPEG2 file plus a SRT subtitle file and outputs a MPEG2 file with burnt in subs. (NOT an AVI as the above combination does)
I can do it by converting the MPEG2 file to avi, using the above utilities or even AutoGK set on 100% quality, add the burnt -in subs and then convert back to MPEG2 but it would be nice if it could all be done with MPEG specific software that would only require one recode.
Thanks![]()
So does this mean as an example I select my mpeg file called BigTop.mpg and subtitle file BigTop.srt, process it and the resulting file will be BigTopSpecial.mpg? If that is the case it solves the problem... many thanks
Just to explain a little on playback - the playback device is not a computer or DVD player but a MPEG2 specific only playback device in development. So the requirement is to have a mpeg2 file that has burnt in subtitles just as if they were mixed in by a video mixer in a studio.
So this device has no capability to install anything just playback a mpeg2 file presented to it and spit it out to a PAL composite output signal plus audio.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hi-
You mentioned AviSynth in the first post, so I assumed you already had some experience in using it.
Yes, load the VSFilter.dll and then you can use text based subs (SRT, SSA, etc.) with the TextSub command, and VobSubs (IDX/SUB) using the VobSub command in the script. You also make a D2V project file using DGIndex, but I guess you already know how to do that. Depending on the colorspace of the source and the encoder you're using, you might want to add a ConvertTo (whatever colorspace) at the end. Open the script in VDub(Mod) first, and scroll around to make sure the script's OK and that the subs show up. Then send to whatever encoder you plan on using. This processes the video only. Mux in the audio when done.
Adding selectable subtitles to an existing dvd with a mac
By chiappa in forum MacReplies: 5Last Post: 17th Mar 2012, 20:00 -
Adding subtitles to an existing DVD (the easy, lazy way)
By muppetsunited in forum User guidesReplies: 0Last Post: 27th Jan 2011, 07:49 -
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 19:43 -
Adding English subtitles to existing DVD on a Mac?
By Eug in forum MacReplies: 5Last Post: 29th May 2010, 17:13 -
adding new subtitles over existing ones
By fishdog in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2010, 02:22
