This has been my worse nightmare.. i just cant do any of this conversion stuff
I have used programs but they just crash on me or just stuff doesn't work etc.. and im probably pissing everyone off here asking for help
I wondered if there was anyone out there who could do it for me?
I was thinking if they had an ftp server or something i could upload the clips to etc?
Here is what needs doing..
I have 2 clips - 160x120 - 41mb and 56mb
I have another 3 clips - 320x240 - 1.6gb and 199mb and 5mb
I want to join all these together and just have one file......I will then replace the audio with a decent audio recording and then burn to a dvd.... but just getting 1 long clip would be a success
OR
if someone could kindly write me a step by stepd guide telling me what programs to get and what to do..
anybody? heh ?
thanks people
Ed
Results 1 to 20 of 20
Ok try this first:
https://www.videohelp.com/convert
Also you need to detail the type of files they are not just the length. Use gspot or avicodec to find out what they were encoded with.
Another thing - you may have a divx capable dvd player already. If so you could be able to just simply burn the files on to a data dvdr and then play them that way. Though with so many different video formats out there it's hit or miss on success rates.
Try an all in one tool like super or even a trial run of tmpgenc dvd author 3 which now will convert internet video into a dvd for you - though its payware but comes with a trial.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Try downloading WinAVI Video Converter ...free trail download... although limited functions
it should convert your small clips to DVD. At least it will get you used to some converting proccess.
http://www.winavi.com/en/video-converter/video-converter.htm
The program that came with your DVD burner should edit your clips, or ask someone to borrow theirs. Failing that try a free trail download of Ulead® VideoStudio
http://www.ulead.com/vs/
Remember everybody has to learn and its not that hard with right programs.
videohelp forums helped me no end in my early editing days. -
As I asume you have the files aready on your computer, make them straight to mpeg 2 or dvd ......
Capture into AVI when putting clips into the computer from another source, such as a camcorder or vcr tape recorder, then convert to DVD -
use convertxtodvd, if you look on the page, there is a free version. then use tmpgenc dvd author to combine the clips
member since 1843 -
Frankly I wouldn't use WinAVI in a fit, and I wouldn't use ConvertXtoDVD for this job either. ConvertXtoDVD will only output full-D1. Given you have postage stamp video to start with, blowing it up to 4 and 8 times the original size will make look horrible. You should target VCD resolution on DVD to preserve what little quality you can.
Read my blog here.
anyone know any programs where i can take replace the sound of my file with something else i.e a better recording of a concert
also im using Nero and using Make your own dvd.. i add my 5 clips and once the dvd is done it just plays the first clip..
anyway i can merge these without making them the same resolution? -
No. Simplest would be to use Tmpgenc Plus to encode them all to VCD resolution (using the VCD template) then use mpeg tools (part of Tmpgenc Plus) to join them.anyway i can merge these without making them the same resolution?
You can add any audio you like when you author with a decent authoring tool. Nero is not a decent authoring tool so it may not be able to do this, and will probably re-encode your video.Read my blog here.
TMPGEnc Plus has audio/video muxing and demuxing tools.
If your individual sources are AVI files and you have audio files ready for each one you can use VirtualDUb to replace the audio with a WAV files, or VirtualDubMod to replace with AC3, MP2 or MP3 files. -
tmpgenc plus does not accept my filesOriginally Posted by guns1inger
i ran gspot on one and these are the stats.
This is one of the 160x120 clips
http://img521.imageshack.us/img521/1555/untitledjt9.jpg -
Those appear to be MJPEG format from a digital camera. Windows Movie Maker should accept them. But WMM only outputs WMV or DV AVI.
With TMPGEnc, you may need a MJPEG codec to open them, not sure. TMPGEnc may need the VFAPI priority raised. See here down the page a bit for 'Problem opening source files:. http://www.digitalfaq.com/dvdguides/convert/tmpgenc/tmpgenc.htm
Or try SUPER and convert them separately to VCD MPEG-1 format, no audio. Then you can add your own audio in when you author. Or convert the audio also with SUPER if you want to use it. Since they are low resolution, MPEG-1 is probably fine. For a DVD, they will have to be a standard resolution, framerate and compatible audio. See 'WHAT IS' DVD to the upper left for DVD format and specifications.
If you have TMPGEnc DVD Author, that will accept the DVD compliant separate clips and you can add the audio files separately and it will make them all play as a single video.
Or you can use the freeware GUI for dvdauthor. It accepts separate video and audio also. -
thanks you all for your help
you guys totally rock
yupp
they are digital camera videos -
wow
why is WMM giving me this error?
http://img453.imageshack.us/img453/433/untitledzx7.jpg
dont know why the screenshot double ;p
My files are in the same directory.. im saving to the same folder.... i have 19gb free hardrive space and its meant to be 3gb big..
so what the hell is wrong :S -
illegal character in filename?
path name too long?
writing to a read only share?
file already exists, can't delete it? -
i have tried saving to different partitions
i leave the file name as untitled -
Hey couldn;'t he add borders to the postage stamp sized vids with Vdub? Just to make them the same width and height? Then, he could use Nero (even if using Nero is blasphemy around here
) to merge them.
Just my two öre.
I didn't read the whole tread, sorry if thats already been addressed.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
wow, do you have a bell on this thing or something?
how did you reply in the same minute as i?
I meant using Nero Vision Express from Nero 6. I thought u had used that before? It's like 35 mb. to download, trialware or something.
As long you don't have to add subtitles, Nero is IMHO the best for the job.
You don't have to learn much, actually nothing at all, it's all drag and drop.
Nero Vision Express doesn't really care if it's AVI or Mpeg either, or what size, I must admit I have never tried to add videos that small.
But yeah, that's not "REAL" DVD-authoring in the opinion of some around here, so they'll look down upon you and yell at you.
You could use VirtualDub to add and delete sound from an AVI, as long as its sound is CBR and not VBR, you can do that.
Do u know how to add borders in VirtualDub?Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
Should you pay for new software version?
By johns0 in forum PollsReplies: 9Last Post: 11th Mar 2011, 11:00 -
How do you pay your bills?
By johns0 in forum PollsReplies: 8Last Post: 10th Mar 2010, 10:03 -
Aussies ? Pay TV help.
By fredfillis in forum Off topicReplies: 1Last Post: 28th Oct 2008, 17:28 -
Freedom from Pay-TV!
By retro junkie in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Sep 2008, 22:23 -
Best MP3 pay sites out there?
By Super Warrior in forum Off topicReplies: 9Last Post: 16th Apr 2008, 18:37
