Hello,
my fanless psu gives off RFI on my tv when my computer is turned on, as soon as I turn it off the interference disappears. Someone suggested that I plug it into an rfi filtering power bar but that didn't work at all. any ideas on how I can get rid of this interference and keep the power supply? I like the low noise but I still wanna be able to watch tv at the same time. thanks
	hiya nick-
 you need to figure out if the cords are broadcasting the RFI, if there is some positioning issue with your TV etc. If you have cable it shouldn't be able to get into your TV on the coax. I wonder if your computer is grounded at all...
 if the RFI is coming thru the wires in the wall, the filter should have worked.
 if it is being broadcast by the PSU wires, you can fold them & tie-wrap'em - the idea being to get their unwanted 'signal' to cancel itself as much as possible
 if it is coming from the brick itself, or just the wire after the converter brick you can shield the unit in various Rube Goldberg ways- any grounded metal or or one of those cable RFI traps should work. For example, ground one of those cheap 2 drawer filing cabinets and stick the PS inside!
  Need to choose a power supplyBy neworldman in forum ComputerReplies: 4Last Post: 4th Aug 2010, 08:26
  Power Supply to FanBy HotDamn! in forum ComputerReplies: 9Last Post: 23rd Mar 2010, 05:13
  Bad Power SupplyBy AuroEdge in forum ComputerReplies: 4Last Post: 14th Jan 2010, 00:41
  Power Supply QuestionBy jjis in forum ComputerReplies: 10Last Post: 6th Nov 2009, 08:35
  fixing an old TV (power supply)By moviegeek71 in forum Newbie / General discussionsReplies: 21Last Post: 16th Oct 2008, 15:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
