Hi,
I just started having a problem w/my Pioneer DVR-105 where it won't recognize DVD-RWs. I tried burning to the same Memorex DVD-RW I've been using for a while but got an error "PIONEER DVD-RW DVR-105: Illegal disc. Please insert a rewritable disc". This disc was pretty scratched so I bought new ones, again Memorex but I still got the same error. I also tried this drive and a new -RWs in other apps but none recognized the disc and said there was no disc in the drive. Unfortunately I have no DVD-Rs to try.
I saw some info re DVRFlash to change the firmware, could this help? If not, any idea what else might help? thanks!
	It's time to invite a few friends over and say a few kind words of remembrance over you OLD and tired 105 and then take it out of its misery and bury it. It probably has cataracts of its laser by now. Even if you perform laser cataract surgery, virtually none of the media that you can buy now is supported in its Media ID (MID) table in its firmware. Pioneer no longer updates the firmware MID table for the 105. This being the case, you will not get optimum burns even if everything in the drive is OK or fixed. You can buy a new Pioneer 112 for well under $40 if you look around. For example http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+50001167&name=Pioneer
	Use wrong DVD-RW media and you can easily destroy that burner.........
  Pioneer DVR 520-H does not recognize discBy Steve_Rbts in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Sep 2010, 00:35
  Illegal Disc errorBy smackypete in forum Authoring (DVD)Replies: 10Last Post: 19th Jun 2008, 20:00
  Guide to fix Illegal Disc Error for NEC drive (possibly others)By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 02:11
  Illegal Disc ErrorBy ScottM808 in forum DVD & Blu-ray WritersReplies: 25Last Post: 12th Jul 2007, 15:51
  Q: for Disc Jockeys Pioneer DVR-111D / DVR-710By edDV in forum DVD & Blu-ray WritersReplies: 10Last Post: 14th May 2007, 23:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote![[_chef_]'s Avatar](customavatars/avatar30571_1.gif)
