Hi i just bought a diamond vision Model v809-04 it can play most my region 1 but some dvds i get no disc error! !! I usually download my moives and use this program to burn avi files to a dvd!! Those moives dont work keep getting no disc error!! Works fine on my other brand dvd player!
IS there any hack!
Most likely a DVD media issue, especially if the discs work in other players. Some players are picky about the brand/type of media that they can use.
You will need to find out what brands/types of discs that can read or replace it with another make/model. Since it is new, I would just return it.Google is your Friend -
Question, Are you trying to get it to play AVI files? Or are you converting them to Standard DVD?
It is possible that this is a DVD only player and not a Divx player.
Need help with Diamond One Touch Video Capture
By leoorl in forum Video ConversionReplies: 3Last Post: 28th Apr 2012, 10:11 -
VCS Diamond 7.0.29 Echoes
By Nagashi in forum AudioReplies: 0Last Post: 12th Jan 2012, 08:23 -
Diamond VStream any feedback?
By halekon in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jul 2011, 13:35 -
Diamond ATI TV Wonder HD 750 USB
By Caple in forum Capturing and VCRReplies: 4Last Post: 16th Jul 2010, 21:39 -
Nero Vision to convert .dat file to DVD disc - AUDIO ISSUE
By tlj in forum Video ConversionReplies: 1Last Post: 31st Dec 2007, 17:32
