Gang,
I need your help. I recorded a *.ts program via OTA with my DVICO FusionHDTV 5 USB. I can play complete recording back without any problems, but when I try to edit or anything it hangs whatever piece of application I use.
I tried to edit out commercials using Womble MPEG Video Wizard and VideoRedo Plus, but both hung at the same point in the file. I tried demuxing with DGIndex which created the project file without a problem, but the audio was cut off at the same point the previous video editors were.
I tried fixing the *.ts stream with VideoRedo Plus, MPEG2Repair and Project X, but all could not fix the 5.1 Dolby audio stream.
Is there a piece of software available that can fix and extract this audio file, so that I can then edit as I like?
Thanks.
Try demuxing with xport.exe http://www.w6rz.net/xport.zip
Syntax xport FILENAME.TS 1 1 1
The resulting .mpa is actually an ac3 - run it through AC3Fix -
I tried that with VideoRedo, but it got hung on the problem spot of the file and gave an error message that file couldnt be completed ......yada yada yada. I dont think I tried stream fix with MPEG Video Wizard and not sure if it offers this utility, but if it does, I am not going to hold my breath that it will work either.
Try mpeg streamclip to take what you need , leaving the add's behind .
Holy moly!!!!!! I tried MPEG Streamclip first and it worked. What I did was open the problem file and just saved as a new TS file. I checked the new TS file in Videoredo to see if it was performing normally. VideoRedo opened and edited the file without any problems.
Thanks to you guys for the help.
Cannot extract an h264 out of a transport stream (.ts --> .mp4)
By dirk205 in forum Video ConversionReplies: 0Last Post: 13th Sep 2011, 02:39 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
no audio from transport/program stream file when i try to encode
By uptonm in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2010, 10:41 -
DVD to MPEG2 Transport Stream audio sync problem
By elba in forum Video Streaming DownloadingReplies: 12Last Post: 23rd Oct 2008, 02:09 -
multiple audio tracks in transport stream
By levide in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 12:58
