I have a .ts file that I captured with CapDVHS. The file sounds great when I play the .ts file. When I convert the file using HDTV2DVD the resulting MPEG has low volume. There is a big difference in volume levels between the original .ts file and the converted MPEG.
Is there a way to get the converted MPEG to have the same volume level as the .ts file?
Thanks for the help!!!
Thank you for your reply. I'll try some different players and check the results.Originally Posted by Soopafresh
Thanks!
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 12:27 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 07:07 -
HDTV2DVD (ffmpeg) crashes due to low memory
By thobhall in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Feb 2008, 08:39 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
