Results 1 to 11 of 11
    Jun 2007
    Netherlands
    I am having some problem, the icon of harddrive HDD (D) has auto changed into someother icon. And I wont like it, I was trying to change it back as the way it was earlier just like HDD (C) .
    I will be thankful. here is screeshoot.
  2. Did a reboot fix the problem?
    If not, might want to try this
    HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/Explorer
    Create a key called DriveIcons. Within DriveIcons, create another key with the drive letter you want to change (..\DriveIcons\K). Create another key within the drive letter key called DefaultIcon. Set the default value equal to the icon you want to use. If you have a file that has more than one icon in it, such as a DLL file, use the standard C:\full_path\icon_file.dll,x <file:///C:/full_path/icon_file.dll,x>) where x is the number of the icon within the file icon_file.dll.
    You can change a hard drive's icon in any 32-bit Windows platform by including a valid Autorun.inf file in that drive's root directory. Windows Desktop Update presents another way to change a hard drive's icon. To change the icon for drive C:, insert the name and (optional) icon index number of a valid icon file as the (Default) value for this key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\explorer\driveicons\C\DefaultIcon. Replace C with a different letter to change another drive's icon.
    Originally Posted by jagabo
  3. Found an easier method
    Try
    http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
    There is a icon rebuild option in there
  4. check if you don't have an autorun.inf file on the root of your D drive
    Jun 2007
    Netherlands
    Dear friends,
    Thanks lot for your help. Unfortunatly I did all procedure one after another but nothing happen the icon is still on its place.
    1-
    2-
    Nothing happend above both procedures!
    3-
    autorun.inf
    I have autorun.inf file in both drives. Now i am getting confuse.
  6. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    That icon you now have for D: is the one Windows uses for unrecognized program.
    Did you change/install/run something just before this happened?
    Does D: still work OK? Can you access it?
    Jun 2007
    Netherlands
    yes, i access every thing, its working fine.
    Jun 2007
    Netherlands
    Originally Posted by stiltman
    insert the name and (optional) icon index number of a valid icon file as the (Default) value for this key..
    Could you let me know how could I found the name or index number of the icon.
  9. Mod Neophyte redwudz's Avatar
    USA
    To find the icon index number:
    The one highlighted there is #12.
    From: http://www.pcmag.com/article2/0,1895,1847172,00.asp
    Jun 2007
    Netherlands
    redwudz. .
    thanks alot
