  1. I used a small application called "extractor" the fastest vob joiner I ever found. HOwever I cannogt locate it anymore. I googled but no luck
    Does anyone know where can I find it, or suggest another vob joiner?
    MediaStreamClip 1.8 crashes on my Intel Mac, and 193 hungs
    I am not sure which Unix component they use for this task: certainly mplayer binaries does not work properly with Intel Macs
    Any hints?
    Aug 2005
    Palo Alto, California USA
    D-Vision3, aside from being an excellent DVD-to-DivX/XviD converter, also has a collection of useful utilities, among which is a VOB joiner. And it's free. Give it a shot.
    Jun 2006
    When all else fails, you could concatenate them in the Terminal
    cd ~/Desktop/MOVIE/VIDEO_TS/
    cat VTS_01_[1-5].VOB > joined.vob
    The first line is changing to the proper directory, and the second line is joining VTS_01_1.VOB through VTS_01_5.VOB.
    You will, of course need to change directory names and VOB names to make it work for you. Also, this may not work properly if there are special scenes/angles in the video.
  4. Does joining the VOBs via the cat -command introduce timecode breaks?
    MPEG Streamclip is the only (decently priced ) app that I have got to properly join MPEG1/2 files. All other apps introduce timecode breaks.
    VLC doesn't normally care about the timecode breaks but QT Player (and MPEG Streamclip) want them to be fixed; otherwise they don't play the whole clip. ...and many MPEGs do have those breaks, and I wonder where they were introduced
