Hi all,
I have some video files in DV-DVI type1 format. The video is NTSC 720x480 29.94 fps
I need to be able to process these files through ffmpeg. ffmpeg work great with PAL resolution video in the same format but fails processing NTSC.
I get an error about swScaler cannot find context.
Does anyone know how to get ffmpeg to process NTSC clips?
Vert
Results 1 to 19 of 19
Sorry i should have thought to include it in my first post.
The error is different, i think the other error must have been from some other variation that i tryed yestreday.
C:\>ffmpeg.exe -i c:\answer1_ntsc.avi c:\answer1.yuv c:\answer1.mp3
FFmpeg version SVN-r8435, Copyright (c) 2000-2007 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --
enable-liba52 --enable-avisynth --enable-libdts --enable-libfaac --enable-libfaa
d --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libogg --enable-l
ibtheora --enable-libvorbis --enable-x264 --enable-xvid --enable-amr_nb --enable
-amr_wb --cpu=i686 --enable-memalign-hack --extra-ldflags=-static
libavutil version: 49.3.0
libavcodec version: 51.39.0
libavformat version: 51.11.0
built on Mar 18 2007 22:27:19, gcc: 4.3.0 20070126 (experimental)
[avi @ 009FEB90]Could not find codec parameters (Video: dvvideo, 25000 kb/s)
c:\answer1_ntsc.avi: could not find codec parameters
C:\> -
works for me.
update your ffmpeg version.
http://esby.free.fr/CelticDruid/mirror/ffmpeg/
try again.
upload a sample if it doesn't work
gl -
you might try converting to type II avi before processing.
https://www.videohelp.com/tools/Canopus_DV_File_Converter--
Yes. Sure.Originally Posted by Vertuas
Probably your source,
upload a non-working sample somewhere if you'd like someone else to have a shot at it. -
Hi
I uploaded a test video clip at
www.videoboothsystems.co.uk/uploads/test_type1_ntsc.avi
The file is 77.6 Meg in size.
Vert -
Yes there's something wrong with your file.
The header for one.
Can't say i'm too concerned with the actual problem as there are plenty of options open to you.
Why yuv btw?
1. use avisynth
Code:directshowsource("dv.avi")this worked for me.Code:ffmpeg -i dv.avs dv.yuv dv.mp3
2. just use vdub to convert to something like huffyuv or uncompressed rgb. (separate audio proc)
3. direct stream with vdub and run through mplayer/mencoder. (separate audio proc)
4. convert to dv type 2 and run through mplayer/mencoder.
encode wav with lameCode:mplayer dv2.avi -ao pcm:fast -vo yuv4mpeg
weird ffmpeg won't take the type 2 avi or re-streamed dv, it doesn't seem to be able to detect the colourspace and fails.
anyway
gl -
Hi All,
I am converting a few files to yuv and mp3 then getting ffmpeg to join them to make one large video file.
It was suggested to me (not on this forum) that i need to convert the video to a common format before trying to join them up. yuv and mp3 was suggested to me.
Hope this helps
Vert -
Update.
I used After Effects to create a ntsc video file and that one work perfectly. Must be dodgy video that has caused my problems.
Another question :
Can ffmpeg re-convert my yuv/mp3 files back to dv avi? I can get them to go back if the video is PAL to PAL, but not with NTSC to NTSC?
C:\>ffmpeg -i test2.mp3 -acodec pcm_s16le -vcodec dvvideo -s 720x480 -r 29.97 -i
c:\test2.yuv c:\test2_m.avi
Input #0, mp3, from 'test2.mp3':
Duration: 00:00:04.1, start: 0.000000, bitrate: 63 kb/s
Stream #0.0: Audio: mp3, 44100 Hz, stereo, 64 kb/s
Input #1, rawvideo, from 'c:\test2.yuv':
Duration: N/A, bitrate: N/A
Stream #1.0: Video: rawvideo, yuv420p, 720x480, 29.97 fps(r)
Output #0, avi, to 'c:\test2_m.avi':
Stream #0.0: Video: dvvideo, yuv420p, 720x480, q=2-31, 200 kb/s, 29.97 fps(c)
Stream #0.1: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Stream mapping:
Stream #1.0 -> #0.0
Stream #0.0 -> #0.1
Press [q] to stop encoding
Video encoding failed -
I said as muchOriginally Posted by Vertuas
quite frankly, that sounds ridiculous.Originally Posted by Vertuas
what's wrong with dv? or something lossless like huffyuv?
And why on earth would you go to mp3 for joining/editing when you've got uncompressed audio staring at you?
See the foolishness?Originally Posted by Vertuas
pcm to mp3 to pcm??
Yes. Why not ntsc?
try:
glCode:C:\>ffmpeg -i test2.mp3 -i c:\test2.yuv -acodec pcm_s16le -pix_fmt yuv411p -vcodec dvvideo -s 720x480 -r 29.97 c:\test2_m.avi
Hi
You are quite correct it does appear silly going from uncompressed-compressed-uncompressed as the loss of quality.
The intermediate formats are things that i have been left to work with from someone else, there is no reason why they cannot change.
The DV input and DV output must stay the same however the output can be type 2, thats not a problem. The inputs are type 1 as they are from a DV Video camera.
Before attempting to sort out the mess that i was left with, i had never use ffmpeg before! Is a rapid learning experience indeed!
I appriciate your help very much. -
Hello
I just found the reason for the use of MP3 audio.
If i use wavs, the audio doesn't get muxed properly on the merged output. Only the audio from the first video gets included.
So back to MP3 then.
Again Thank you very much for all your help
Vert -
out of interest,Originally Posted by Vertuas
using what commandline? -
Hi 45tripp
All of the video to be joined get put into one folder. Command line :
ffmpeg -i input.avi -pix_fmt yuv411p input.yuv input.mp3
change yuv411p to yuv420p for PAL input video.......if you don't include the pix_fmt, the NTSC clips don't go back to DV-AVI correctly! You need to do this for each video to be joined up.
Then all the YUV files get appended into on big YUV file.
All the MP3 files get appended to one big MP3 file.
Then for NTSC :
ffmpeg -i merged.mp3 -acodec pcm_s16le -pix_fmt yuv411p -vcodec dvvideo -s 720x480 -r 29.97 -i merged.yuv merged.avi
or
ffmpeg -i merged.mp3 -acodec pcm_s16le -pix_fmt yuv420p -vcodec dvvideo -s 720x576 -r 25 -i merged.yuv merged.avi
for pal.
You cannot cross covert between PAL/NTSC. All input video clips must have an audio track and be the same format (NTSC/PAL).
I beleive that after the header issue, it was ommission of the pix_fmt option in the extract for the AVI that was causing my problems, as NTSC was saved as yuv420p not yuv411p. The resulting video content was just a mass of shapeless color.
The missing header issue was caused by DVDate which i had used to convert my PAL test files to NTSC. NTSC video from After Effects work fine.
Vert
MKV Audio + AVI Video to avi using ffmpeg?
By kwanbis in forum Video ConversionReplies: 9Last Post: 15th Apr 2012, 21:45 -
ffmpeg won't convert files from Pal to NTSC, mpegstreamclip does
By ruggerjvd in forum ffmpegX general discussionReplies: 2Last Post: 8th Jun 2009, 09:39 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
FFmpeg: AVI to Rawvideo
By David_UK in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 10:07 -
Subtitling an AVI in ffMpeg
By iMacG5Usr in forum ffmpegX general discussionReplies: 12Last Post: 12th Aug 2007, 13:17
