Hi, my first post here, not that young reading this forum.
I made a small "intro" on premiere and I tried to append it with another avi with virtual dub.
Both supposedly have the same frame rate (23.976) but every time I tried to append, and error is showing that one of them is (23.97606) and other is (23.97600) I tried by manually change the rate to the intro (is just 5 seconds long) but is always a nano difference.
I did the same thing with a video with 29 fps and the same error y showing. By some reason is always a jiffy of a frame messing around and I dont know how to fix it.
Help!! thank you and bear with my english.
Results 1 to 14 of 14
Try changing/setting the frame rate with avifrate, and make sure both are the same.
/Mats -
When you applied the different frame rate , you did resave it as a new avi , and tried after , to join using the new file instead ?
yes, everytime I applied the change, I saved it as avi and try to append it again
Change them both to a new and same framerate, like 24fps, join them, and when all done change it back to 23.976fps.
The problem is that the frame rate in an AVI file is specified by two integer values, a numerator and a denominator. When programs show you the frame rate they usually convert them to a floating point values, divide one by the other, and display two or three digits to the right of the decimal point. There are two possible problems with this:
1) One program may specify 25 fps with a 25 and a 1. Another may use 2500 and 100. These are both exactly 25 fps but a program that's comparing them may decide they're different because tha actual values are different.
2) A program might specify 23.976 as 23976 and 1000. Another might specify them as 24000 and 1001 (this is the true NTSC film frame rate). Not only are the raw values different, but the calculate fps is slightly different, 23.976 and 23.9760239760239760...
The solution is to use AVIFrate and make sure both the numerator (rate) and denominator (scale) are the exact same values. You may have to change both files to do this. Change the scale value first, then set the fps. The program will automatically generate the rate value. -
Thank you for you help guys! I will try with Avirate and I would tell you that happen
Actually now is showing this error:
Cannot append segment "C:blahblach" The video streams have incompatible data formats
(Mismatch detected in opaque codec data at byte 21 of the format data)
damn this is annoying! -
Virtualdub doesn't work very well for joining files like this.
What I have found that usually works is taking the audio out and joining the audio files together with an audio editing program (Goldwave) > changing the framerate of each clip from 23.976 to 23.976 and direct stream copy the video to a new file without audio.
You should now be able to append the video clips and add the wave file and direct stream copy the video and compress the audio and save as your finished AVI. -
When appending, AVIDemux is less picky than VirtualDub about minor differences between AVI files.
Well, to append AVIs with VirtualDub, all pieces must have the same characteristics; frame rate (as you've already fixed), resolution, audio and video codec, audio and video bitrate.Originally Posted by lilith2014
/Mats
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 18:49 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 02:13 -
AutoGK : MPEG2 to Avi Frame Rate Problem
By Mokkori Chan in forum Video ConversionReplies: 6Last Post: 27th Feb 2009, 03:51 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 03:31
