I had 2 avi files in which i used VDUB to paste on Subtitles then i joined the two files and then tried to convert the file and its out of sync the original source i think is PAL but does that matter when you are encoding to NSTC. It is out of sync by quite a bit. I tried playing around with the frame rate and no luck. It seems to be insync for the first 4 min then goes out of sync. Can someone PLEASE HELP!!!. THanks!
unfortunatley converting PAL to NTSC is not as easy as just clicking an option in TMPGEnc.
try checking out this thread...
http://www.vcdhelp.com/phpBB/viewtopic.php?t=71671&highlight=
warning: this is not a short thread -
just curious but what the hell would the file format have to do with the framerate that is the obvious problem in converting?
simple answer... frame rates different, not good. framerates same, good.
if thats not enough of an answer i suppose you could actually read that thread.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
I read the thread and it said to extract the audio now tell me how the hell am i supposed to extract the audio from the avi and only encod the video huh tell me how then that might solve my prob.
I have sometimes had problems with Virtual Dub subtitle filter together with DIVX to MPEG.
My personal solution: Encode first to MPEG (without subtitles), then open the resulting MPEG file in VirtualDub, add the subtitles and frameserve to TMPGEnc for the final result. Seems to work better that way for me.
Cheers -
if i dont have the original AVI without subs am i SOL. The avi i made with subs is not outta of sync though.
load your avi in VirtualDub, select the file pull down menu and click Save Wav and you will get a wav file of the audio.Originally Posted by iomega400
load your avi in VirtualDub and select direct stream copy in the video pull down menu. then select No Audio in the audio pull down menu. select save avi and you will get an avi file with no sound.
you could do it with TMPGEnc also, thats why they included that little stream type box in the program.
sorry for assuming you knew how to use VirtualDub and TMPGEnc, i seem to make the mistake of thinking that people might spend a few minutes looking into things or trying things on their own.peace out,
dumwaldo
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:56 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 15:39 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 22:51
