I updated to the newest version of ffdshow by first uninstalling the old version. The FilmMachine now encodes with no audio? How do I go about updating the ffdshow.reg? I updated to version r1421 2007-08-15
Thank you
-The Mang
You may not have ffdshow set to decode/encode everything you need. Under ffdshow's Start menu folder, open "Audio decoder configuration" and see what's enabled or disabled in the Codecs section.
If cameras add ten pounds, why would people want to eat them? -
I'm converting avi's to DVD. Would doing what you suggest cause conflicts with the Xvid codec which is also on my PC?Originally Posted by Ai Haibara-The Mang
There shouldn't be a problem. I haven't experienced any conflicts with having both ffdshow and Xvid installed, on multiple systems. In fact, if you're concerned, you can open the video configuration options, under Codecs, and have ffdshow use the version of Xvid you have installed, to handle Xvid and DivX 4/5/6 video.
We're just dealing with the audio setup here, though.
Also, in more recent versions, ffdshow has an 'exclude list' you can set, telling it which applications should or should not use it to decode video, just in case there are any conflicts or weird behavior.If cameras add ten pounds, why would people want to eat them?
updating drivers
By romanstopme in forum ComputerReplies: 7Last Post: 9th Oct 2008, 13:09 -
The FilmMachine problems
By olson311dude in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 05:58 -
The FilmMachine v1.6.0.6 Beta is out
By louv68 in forum Latest Video NewsReplies: 0Last Post: 9th Aug 2007, 16:12 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
Upside down movie after the filmMachine
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 07:29
