I am trying to make 2 divx files into a dvd with a menu and as soon as i click create dvd it crashes and i get the following error
Problem signature:
Problem Event Name: APPCRASH
Application Name: SVCD2DVD.exe
Application Version: 2.5.3100.0
Application Timestamp: 0000002a
Fault Module Name: StackHash_51c4
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549bdc9
Exception Code: c0000374
Exception Offset: 000af1c9
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 2057
Additional Information 1: 51c4
Additional Information 2: b5c17f3b79014c88d3316be042025464
Additional Information 3: 60ec
Additional Information 4: 742a6af799ceb2dda6830d18eec3107a
Results 1 to 17 of 17
Is there a log for this run?
i dont seem to have a log folder, is it something that needs to be turned on?
Help->Open Logs
Is this on Vista?
Have you seen this post: https://forum.videohelp.com/topic324278.html#1672927
The run as adminiatrator pointer may help you.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I just tried run as administrator and still crashed the same and i still am not getting any logs produced?
ok. is it all assets or just the ones you are currently using?
as far as i know just the ones i am using now, i used it a couple of weeks ago and no problems but these assets seem to be crashing it
Sorry been away....
I tried the same files as you and couldn't replicate it. Have you had the issue with others since then?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I'm running into a similar problem, but mine occurs when I add assests. I just uninstalled and re downloaded so I have the most recent version, and I am running as administrator. I was previously able to use once, but two of the files came out corrupted and I was retrying. The error pop up reads "SVCD2DVD 2.5 has stopped working" "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
I am on Vista Ultimate 32 bit.
Here is the "problem report" for one of the failures.
Problem signature
Fault Module Name: StackHash_74f6
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 74f6
Additional Information 2: 8c84fed71b7f4479d104944cffc9e322
Additional Information 3: 0490
Additional Information 4: 865278a17425bd405f99996d6df29800
Extra information about the problem
Bucket ID: 511089024
Any help would be greatly appreciated.
Thanks. Todd -
what is the path and filename of the asset which causes the crash?
SVCD2DVD crashes, HDTV2DVD runs ok
By silicon101 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 16:32 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 07:35 -
SVCD2DVD and i7
By ttyke32 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th Mar 2009, 15:01 -
svcd2dvd
By tempac in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2008, 22:43 -
What DVD-RW 2x discs can I use with my Pioneer DVR 3100
By longhaireddud in forum MediaReplies: 2Last Post: 30th May 2007, 12:14
