Problems as follows:
Cannot preview menu prior to creation (could not do this in previous version without error);
No audio after creation;
Background image resolution is impaired;
Anyone got any suggestions?![]()
You need to have a dvd player app on your PC... MPC will do. Associate .ifo files with the player.
Will need to see your log for the rest.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have a DVD Player but the message I get is 'one or more of the arguments are invalid'
Will check to see if my player is associated with IFO files. -
Log file for info.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3100.0
Executable: D:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2707539
Executable CreationTime: 16/08/2007 08:41:48
Executable LastWriteTime: 16/08/2007 19:51:09
Executable LastAccessTime: 16/08/2007 20:28:13
************************* Operating System *************************
Operating System: Microsoft Windows XP Home Edition
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 332 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.95 GB
***************************** Computer *****************************
Computer Manufacturer Name: 939M2
Computer Model: 939Dual-SATA2
System Type: X86-based PC
Computer Name: TERRY
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: TERRY\Owner
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) 64 Processor 3500+
Description: x86 Family 15 Model 47 Stepping 0
CPU Speed: 2.2GHz
CPU FSB: 200MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Processor: RADEON 9250 AGP (0x5960)
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 128 MB
Status: OK
Name: RADEON 9250 - Secondary
Processor: RADEON 9250 Secondary AGP (0x5940)
Mode:
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 5.91 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 18.3 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 42.5 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 41.7 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 13.8 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 9.67 GB
********************* END OF SYSTEM INFORMATION ********************
21:39:15: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
21:39:15: -->: DVDFolders creating VTS
21:39:15: -->: VTS 01
21:39:15:
DVD Folders: Processing D:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuNTSC.mpg...
21:39:15:
21:39:15:
21:39:15:
21:39:15:
---------------------------- ENCODING MENU ----------------------------
TV Standard: NTSC
Image size: 720x540
Resize size: 720x480
21:39:16: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
21:39:16: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
21:39:16: libavutil version: 49.1.0
21:39:16: libavcodec version: 51.27.0
21:39:16: libavformat version: 51.12.1
21:39:16: built on Jul 10 2007 10:38:54, gcc: 4.3.0 20061204 (experimental)
21:39:16: Input #0, mp3, from 'D:\Program Files\BadgerIT\SVCD2DVD v2.5\finished.mp2':
21:39:16: Duration: 00:00:03.9, start: 0.000000, bitrate: 192 kb/s
21:39:16: Stream #0.0: Audio: mp2, 48000 Hz, stereo, 192 kb/s
21:39:16: Output #0, ac3, to 'C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\menu.ac3':
21:39:16: Stream #0.0: Audio: ac3, 48000 Hz, stereo, 224 kb/s
21:39:16: Stream mapping:
21:39:16: Stream #0.0 -> #0.0
21:39:16: Press [q] to stop encoding
21:39:16: size= 109kB time=4.0 bitrate= 224.0kbits/s
21:39:16: video:0kB audio:109kB global headers:0kB muxing overhead 0.000000%
21:39:16: Input #0, image2, from 'C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\background1.jpg':
21:39:16: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
21:39:16: Stream #0.0: Video: mjpeg, yuvj420p, 720x480, 25.00 fps(r)
21:39:16: Output #0, rawvideo, to 'C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv':
21:39:16: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 1000 kb/s, 29.97 fps(c)
21:39:16: video:97kB audio:0kB global headers:0kB muxing overhead 2.232897%
21:39:16: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
21:39:16: INFO: [???] File C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv looks like an MPEG Video stream.
21:39:16: INFO: [???] File C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\menu.ac3 looks like an AC3 Audio stream.
21:39:16: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
21:39:16: INFO: [???] Found 1 audio streams and 1 video streams
21:39:16: INFO: [???] Selecting dvdauthor DVD output profile
21:39:16: INFO: [???] Multiplexing video program stream!
21:39:16: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv)
21:39:16: INFO: [???] VIDEO STREAM: e0
21:39:16: INFO: [???] Frame width : 720
21:39:16: INFO: [???] Frame height : 480
21:39:16: INFO: [???] Aspect ratio : 1:1 pixels
21:39:16: INFO: [???] Picture rate : 29.970 frames/sec
21:39:16: INFO: [???] Bit rate : 1000000 bits/sec
21:39:16: INFO: [???] Vbv buffer size : 126976 bytes
21:39:16: INFO: [???] CSPF : 0
21:39:16: INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\menu.ac3)
21:39:16: INFO: [???] AC3 frame size = 896
21:39:16: INFO: [???] AC3 AUDIO STREAM:
21:39:16: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
21:39:16: INFO: [???] Frequency : 48000 Hz
21:39:16: INFO: [???] SYSTEMS/PROGRAM stream:
21:39:16: INFO: [???] rough-guess multiplexed stream data rate : 1255800
21:39:16: INFO: [???] target data-rate specified : 10080000
21:39:16: INFO: [???] Setting specified specified data rate: 10080000
21:39:16: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
21:39:16: INFO: [???] New sequence commences...
21:39:16: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
21:39:16: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
21:39:16: INFO: [???] STREAM e0 completed @ frame 14.
21:39:16: INFO: [???] STREAM bd completed @ frame 123.
21:39:16: INFO: [???] Multiplex completion at SCR=324461.
21:39:16: INFO: [???] Video e0: buf= 0 frame=000896 sector=00000050
21:39:16: INFO: [???] Audio bd: buf= 14336 frame=000123 sector=00000056
21:39:16: INFO: [???] VIDEO_STATISTICS: e0
21:39:16: INFO: [???] Video Stream length: 101093 bytes
21:39:16: INFO: [???] Sequence headers: 2
21:39:16: INFO: [???] Sequence ends : 0
21:39:16: INFO: [???] No. Pictures : 15
21:39:16: INFO: [???] No. Groups : 2
21:39:16: INFO: [???] No. I Frames : 2 avg. size 27240 bytes
21:39:16: INFO: [???] No. P Frames : 14 avg. size 3288 bytes
21:39:16: INFO: [???] No. B Frames : 0 avg. size 0 bytes
21:39:16: INFO: [???] Average bit-rate : 1514800 bits/sec
21:39:16: INFO: [???] Peak bit-rate : 1038800 bits/sec
21:39:16: INFO: [???] BUFFERING stream too short for useful statistics
21:39:16: INFO: [???] AUDIO_STATISTICS: bd
21:39:16: INFO: [???] Audio stream length 111104 bytes.
21:39:16: INFO: [???] Frames : 124
21:39:16: INFO: [???] BUFFERING min 35 Buf max 707
21:39:16: INFO: [???] MUX STATUS: no under-runs detected.
create sub file....done.
running menu muxer....21:39:17: MUXRATE =4400
21:39:17: after read_bmp(): xd=720 yd=480 x0=0 y0=0
21:39:17: Found EOF in .sub file.
21:39:17: warning, sub on line 0 starts before 4s, (some players won't show it)
21:39:17: subtitle duration: -1
21:39:17: ***************** HERE WE GO EVE.ODD *******************
21:39:17: MenuType: EVEN
21:39:17: subtitle_packet_size: 1016
21:39:17: subtitle_packet_size & 1: 0
21:39:17: subtitle_packet_size mod 2: 0
21:39:17: MenuType==""
21:39:17: MenuType=="EVEN"
21:39:17: final subtitle_packet_size: 1016
21:39:17: max_sub_size=1016
21:39:17: skipped 0 bytes of garbage
21:39:17: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
21:39:17: SVCD2DVD: DVDfolders
21:39:17: -->: DVDFolders creating table of contents
21:39:17: scanning C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\VIDEO_TS/VTS_01_0.IFO
21:39:17: -->: Creating menu for TOC
21:39:17:
DVD Folders: Processing C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\menu.mpg...
21:39:17:
21:39:17: -
That looks like a log from a preview. Have you got a log from a run where there is no audio?
Minus Audio.
Title: 2.5
Version: 2.5.3100.0
Executable LastAccessTime: 17/08/2007 17:37:38
Version : 5.1.2600
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 397 MB
CPU Speed: 2.2GHz
CPU FSB: 200MHz
Video Ram: 128 MB
Status: OK
Mode:
Video Ram: 128 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 5.93 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 18.4 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 42.5 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 41.7 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 13.8 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 9.67 GB
18:40:32: SVCD2DVD: DVDfolders
18:40:32: -->: DVDFolders creating VTS
18:40:32: -->: VTS 01
18:40:32:
18:40:32:
18:40:32:
18:40:32:
18:40:32:
TV Standard: NTSC
Image size: 720x540
18:40:33: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
18:40:33: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
18:40:33: libavutil version: 49.1.0
18:40:33: libavcodec version: 51.27.0
18:40:33: libavformat version: 51.12.1
18:40:33: built on Jul 10 2007 10:38:54, gcc: 4.3.0 20061204 (experimental)
18:40:33: Input #0, image2, from 'C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\background1.jpg':
18:40:33: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
18:40:33: Stream #0.0: Video: mjpeg, yuvj420p, 720x480, 25.00 fps(r)
18:40:33: Output #0, rawvideo, to 'C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv':
18:40:33: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 1000 kb/s, 29.97 fps(c)
18:40:33: Stream mapping:
18:40:33: Stream #0.0 -> #0.0
18:40:33: Press [q] to stop encoding
18:40:33: video:97kB audio:0kB global headers:0kB muxing overhead 2.232897%
18:40:33: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
18:40:33: INFO: [???] File C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv looks like an MPEG Video stream.
18:40:33: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
18:40:33: INFO: [???] Found 0 audio streams and 1 video streams
18:40:33: INFO: [???] Selecting dvdauthor DVD output profile
18:40:33: INFO: [???] Multiplexing video program stream!
18:40:33: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\backgroundES.mpv)
18:40:33: INFO: [???] VIDEO STREAM: e0
18:40:33: INFO: [???] Frame width : 720
18:40:33: INFO: [???] Frame height : 480
18:40:33: INFO: [???] Aspect ratio : 1:1 pixels
18:40:33: INFO: [???] Picture rate : 29.970 frames/sec
18:40:33: INFO: [???] Bit rate : 1000000 bits/sec
18:40:33: INFO: [???] Vbv buffer size : 126976 bytes
18:40:33: INFO: [???] CSPF : 0
18:40:33: INFO: [???] SYSTEMS/PROGRAM stream:
18:40:33: INFO: [???] rough-guess multiplexed stream data rate : 1021744
18:40:33: INFO: [???] target data-rate specified : 10080000
18:40:33: INFO: [???] Setting specified specified data rate: 10080000
18:40:33: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876
18:40:33: INFO: [???] New sequence commences...
18:40:33: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
18:40:33: INFO: [???] STREAM e0 completed @ frame 14.
18:40:33: INFO: [???] Multiplex completion at SCR=7606.
18:40:33: INFO: [???] Video e0: buf= 100516 frame=000014 sector=00000050
18:40:33: INFO: [???] VIDEO_STATISTICS: e0
18:40:33: INFO: [???] Video Stream length: 101093 bytes
18:40:33: INFO: [???] Sequence headers: 2
18:40:33: INFO: [???] Sequence ends : 0
18:40:33: INFO: [???] No. Pictures : 15
18:40:33: INFO: [???] No. Groups : 2
18:40:33: INFO: [???] No. I Frames : 2 avg. size 27240 bytes
18:40:33: INFO: [???] No. P Frames : 14 avg. size 3288 bytes
18:40:33: INFO: [???] No. B Frames : 0 avg. size 0 bytes
18:40:33: INFO: [???] Average bit-rate : 1514800 bits/sec
18:40:33: INFO: [???] Peak bit-rate : 1038800 bits/sec
18:40:33: INFO: [???] BUFFERING stream too short for useful statistics
18:40:33: INFO: [???] MUX STATUS: no under-runs detected.
running menu muxer....18:40:34: MUXRATE =4400
18:40:34: after read_bmp(): xd=720 yd=480 x0=0 y0=0
18:40:34: Found EOF in .sub file.
18:40:34: warning, sub on line 0 starts before 4s, (some players won't show it)
18:40:34: subtitle duration: -1
18:40:34: ***************** HERE WE GO EVE.ODD *******************
18:40:34: MenuType: EVEN
18:40:34: subtitle_packet_size: 1016
18:40:34: subtitle_packet_size & 1: 0
18:40:34: subtitle_packet_size mod 2: 0
18:40:34: MenuType==""
18:40:34: MenuType=="EVEN"
18:40:34: final subtitle_packet_size: 1016
18:40:34: max_sub_size=1016
18:40:34: skipped 0 bytes of garbage
18:40:34: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
18:40:34: SVCD2DVD: DVDfolders
18:40:34: -->: DVDFolders creating table of contents
18:40:34: scanning C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3100.0\menu\VIDEO_TS/VTS_01_0.IFO
18:40:34: -->: Creating menu for TOC
18:40:34:
18:40:34:
18:40:34: -
Ok this is a menu again... Did you add audio?
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Feb 2009, 13:58 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 16:28 -
SVCD2DVD Audio problems
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 6th Mar 2008, 10:53 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35
