Is this configuration is good to edit HD footage?
Here is my configuration
Xeon Quod core Dual Processor x5355 2.66 GHZ
Intel S5000XVNSATA Motherboard (As RTX2 is compatible with 5000x Chipset)
4 Gig 667 memory
Nvidia Quadro FX 4500 or FX 5500 Graphic Card with 512mb memory
RTX2 Video Editing Card
1 x 250 Gig SATA2 16mb Cash System Drive
3 x 500 Gig SATA2 16mb Cash Hard Drive
2 DVD Writer
Win XP Pro
About 500W power supply
No
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Sounds like a HP xw8400
That depends on the source format. Is the camera HDV or AVCHD?
If its HDV, then it should be enough with few to no problems. If it's AVCHD, it may be enough to edit, but it might not be enough to do it in Real-Time.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
That's a fast machine and may be overkill if money is a factor. Define the HD formats you intend to edit. That class of machine is common for editing uncompressed HD (SMPTE-292 I/O). If that is the case, you are missing the SDI interface cards and the external or internal RAID Video Server.Originally Posted by vis
The RTX2 has a detailed list of supported hardware. You are taking a risk using other than certified systems. You will spend more time engineering the system vs. editing. Matrox support will point at you for screwing up the system.
http://www.matrox.com/video/support/rtx2/rec/mb_sys/home.cfm
The RTX2 is a native MPeg2 or DV format card and is not capable of uncompressed editing as far as I know. It is well matched to HDV/XDCAM but converts uncompressed SDI to I frame MPeg2 which is lossy. I see no listed support for MPeg4 based formats. Those would need conversion to MPeg2.
So it comes down to which formats you want to edit and if the RTX2 meets your edit processing and quality needs.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
DV Editing
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2008, 01:48
