    Aug 2007
    Hi,
    I am using Tmpgenc to convert some videos to divx. I also select center keep aspect ratio as group filter for all clips as I want the output files to be exact same resolution. When I add all the videos to be converted in Tmpgenc, then select encode and use a divx profile it converts first video in the list with original resolution but rest of all the files in list also get converted at the resolution of first file in list. (e.g. If the first file in list has res. 640X480 then first file is converted as 640X480 but other files in the list have different res. like 352X240 and those files are also converted as 640X480 with dumb black bars)
    Is there a way that I can convert them all with single click in Tmpgenc keeping their individual original resolutions? thank you
  2. Full Screen (keep aspect ratio) will resize them all to 640x480 and only add black borders where necessary to maintain AR. I guess that's not what you want though.
