I'm using Tmpgenc DVD Author after encoding. Is there authoring software in existence that can batch author? When I encode using Tmpgenc Express I can encode in batch mode, but when it comes to authoring, I need to return to the computer and set it up again![]()
This question was asked within the last two days, so do a search. In that post there is a link to a utility to allow you to batch author with ConvertxtoDVD.
Read my blog here.
I put batch and dvd author in the search box and I couldn't find anything. But thanks very much for your help anyway
Read my blog here.
I've Tried ConvertXtoDVD now. But it encodes also which will make the whole DVD making process too long. I encode in Tmpgenc express because it has more editing facilities. I was looking for something similar to tmpgenc dvd author, but with a batch facility so that I don't have to keep comming back after an author and starting another one. ConvertXtoDVD does this, but it encodes too... I don't need to double encode... this takes a massive amount of timeOriginally Posted by guns1inger
I guess you either don't encode in Tmpgenc Express and use ConvertXtoDVD to everything, or you live with one at a time.
Read my blog here.
Need one app to trim, crop, menu, chapter and author to DVD... in batch!
By bhershey in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2011, 13:06 -
ConvertXtoDVD vs. Tmpgenc DVD Author w/Divx Authoring
By Iron_Monkey in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 21:00 -
DVD authoring software like tmpgenc dvd author
By nic2k4 in forum MacReplies: 9Last Post: 29th Nov 2008, 02:34 -
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 21:36 -
How To Batch Author Compliant DVDS - The Easy Way
By Dilemma in forum User guidesReplies: 12Last Post: 2nd Jan 2008, 04:28
