If the average file size is 700mb, how many should I burn to a DVD+R? As many as I can fit? Is there any downside to filling the disc up completely?
Results 1 to 12 of 12
...if we're not talking about converting to Video DVD (single layer), when I'd say 2 hours tops, which mostly means 1 movie, one disk.
/Mats -
Originally Posted by MJA
If they are Divx player compatible and you have a Divx player, you can use watch them with that. But they may not be too near 'DVD quality'.
If you don't have a Divx player, then you would have to convert them to DVD MPEG format and two is about all you could put on there with any sort of quality. But if you started with a 700MB Xvid, DVD quality was lost with that conversion.
A 4370MB DVD / 700MB = 6.24 movies. But 5 is probably safer if some go over 700MB. -
Can you watch these on a regular DVD player?
Originally Posted by bc633
http://www.amazon.com/Philips-DVP5982-1080p-Upscaling-Player/dp/B000N254LU/ref=pd_bbs_...7297653&sr=8-1 -
Sorry if the post OP lead you astray.
Yeah, I'm burning 700mb files using Nero's Data DVD option, for use in my home Divx/DVD player. The reason I was asking was because I was told once to only burn 5 movies per DVD, for 'protection'. I'll be burning 6 per disc, from now on. Thanks guys. -
Probably because a lot of DVD disc problems occur on the outer edge of the disc.
For me, that has only been a problem burning DVD Movies to cheap media. I have not experienced this problem burning Data DVDs with the same discs.
Also, a 700MB file is around 718,000 kb. I wouldn't try and fit 6 files that were bigger than that.
If you must, either cut off the very end with direct stream copy in VDub or reencode the audio, whatever is more acceptable to you. With the new version of Virtualdub 1.7.3, you can use Smart Render to cut the beginning and end off of a movie and it is faster than using Direct Stream Copy.
How to put a lot of movies into single DVD
By TheEmperor in forum Authoring (DVD)Replies: 9Last Post: 19th Sep 2009, 11:48 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 09:14 -
If I put my wedding movies from dvd to bluray, will the player upconvert it
By bnbhoha in forum Blu-ray RippingReplies: 10Last Post: 21st Apr 2009, 23:35 -
How can I put movies and data files on the same DVD?
By Sam-SS in forum Newbie / General discussionsReplies: 9Last Post: 29th Nov 2007, 05:50 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40
