I have some video torrents i need to get onto a dvd that will play on dvd player.My video files are mvs extension and dvd flick does not support those files,how do i convert mvs to avi or an other supported dvdflick format.
Results 1 to 11 of 11
If they are mvs and mkv then they are probably related to this :
http://www.moviecodec.com/topics/14065p1.html
In which case you may be out of luck.
Can you play them on anything at the moment ?Read my blog here.
mVs is most likely the release group of the torrent, and the bits need to be unrared first.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
musicmatch jukebox visualization (mvs) is what i found it to be called.and it does play on my media players.but cannot get it to tranfeed to dvd format
Could it be (like Forum Troll suggests) it's in fact ????.mVs.avi and you have the option "hide extension of known file types" still active (a stupid Windows default)? Load the file in GSpot and post a screen shot.
/Mats -
It may be that the MVS extension, not the format itself, is the real problem here. Trying renaming the extension on the file to AVI instead of MVS and see if that magically fixes the problem. I strongly doubt that your files are really and truly Mediamatch Jukebox Visualization format, but I suppose anything is possible.
Well heres the deal it is labeled mvs but it is actually a img file,i tried relabeling it but didnt work.Alot of torrents are coming off these sites like this.Usually they are the best but can only play them on the computer,it will burn onto disk but will not play.I really need some help on this
If it is an ISO or disc image then mount it with daemon tools so you can see what's in it before you burn. You may have to extract it and convert it, but you can't while is still an image.
Read my blog here.
i downloaded iso buster and extracted the files but i dont know what to do now.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
NEOGEO MVS PCB with 2Joystick ports on regular Jamma Cabinet
By retroborg in forum Off topicReplies: 0Last Post: 23rd Jan 2008, 05:24 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
convert mvs-tsm.r movie format to iPod?
By kieran_92 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2007, 06:26
