I finally joined youtube.com and submitted my first video upload:
Total file size (Video + Audio) = 57,295,824 (58.444 MB)
Video was:
FourCC: xvid/XVID
Resolution: 320 x 240
Frame aspect ratio: 4:3 = 1.333333
Pixel aspect ratio: 1:1 = 1
Display aspect ratio: 4:3 = 1.333333
Framerate: 29.970000
fpsNumber of frames: 7090 (100)
Stream size: 57,295,824 bytes
Bitrate: 1937.552436 kbps
Audio was:
Audio tag: 0x55 (MP3)
Bitrate: 128 kbps CBR
Channels: 2
Sample rate: 44100 Hz
Stream size: 3,785,456 bytes
Then, youtube converted this file into a flv1 (Flash Video 1):
Size: 9,616,621 bytes (9.171 MB)
Container type: FLV version 1
[ Video track ]Codec: Sorenson H.263
Framerate: 29.962546 fps
Bitrate: 325.248218 kbps
[ Audio track ]Codec: MP3
Channels: 1
Sample rate: 22050 Hz
Sample size: 16 bits
So, youtube reduced the video bitrate from 1937.55 kbps to 325.25 kbps and changed the audio from stereo to mono and reduced the rate from 44100 Hz to 22050 Hz
from youtube.com:
"Your video is limited to 10 minutes and 100 MB.
We recommend the following settings:
MPEG4 (Divx, Xvid) format
320x240 resolution
MP3 audio
30 frames per second"
Here is some info if you want to maximize the quality of your video uploads to youtube
Duration Video Bitrate Audio Bitrate Total Bitrate FileSize-KBytes FileSize-MBytes
2 min. 6000.00 384.00 6384.00 95760.00 93.52
5 min. 2600.00 128.00 2728.00 102300.00 99.90
10 min. 1250.00 128.00 1378.00 103350.00 100.93
Maximizing quality is this manner will assure the best possible quality when youtube transcodes the file into Flash Video (Flv1)
One last point:
As far as I can determine youtube converts your video into 320x240 but DISPLAYS it as 448 x 336 (a 40% increase)
I would like anyone to share their experiences with uploading and displaying youtube videos as well as other sites that do the same thing - my goal is to share videos using the highest quality possible with respect to clip duration and file size limits
By the way I used VirtualDub to encode the XviD and I use Riva FLV Player and/or FLVPlayer4Free to view .flv files and Riva FLV Encoder to transcode .avi files to flv1 and two small utilities: flvmdi.exe and flvmdigui.exe to correct "METAData" re the .flv files
(all of these are "freeware")
Cheers
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 11:33 -
youtube downloaded video audio sync problem
By halekon in forum DVD RippingReplies: 0Last Post: 13th Jun 2010, 20:52 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 13:40 -
My recently uploaded video on YouTube has no video, only audio?
By Nintendo Fan in forum Video Streaming DownloadingReplies: 14Last Post: 17th Apr 2009, 17:15 -
Stereo audio for YouTube (with Maximum quality Video)
By bayme in forum User guidesReplies: 18Last Post: 2nd Dec 2008, 14:16
