    Aug 2007
    Hiya i got about 4 mepg 4's and want to join them, 2 are the main menu/intro and 3 are the main film whats the easiest way of doing this?
    They are all ipod ready so i dont want to affect that if that helps....
    THnaks in advance...
    Aug 2007
    Thanks for the speedy reply this prog looks great im jst having trouble becaus eit all goes well until it starts creating because it say creation complete at the exact start time...
    Aug 2007
    Can anyone reccommend anothe rprogram or how to get round this? everything installed fine but it just isnt creating it...
    Aug 2007
    Anyone knwo another program to join mp4?
  5. Mod Neophyte redwudz's Avatar
    USA
    Depending on what you mean by 'MPEG 4', you could try VirtualDub or VD Mod and use 'Direct stream copy'. You 'append' each file to the first file and then save it all. It will automatically append also, depending on the file names.
