I need to know how to setup media player classic to play .m2ts or .mts files. (Sony hdrsr1) I would like help setting up media player classic and CoreAVC Professional.
Results 1 to 10 of 10
I installed Halii but am such a newby I don't know how to use! Simply, I would like to play 00003.mts located on this board!! then I think I can get my files to play-- thank you, Ed V
Double click on the MTS file. Windows will tell you it doesn't know what program to use. Select "Select the program from a list", press OK. The "Open with" dialog should open with a list of possible programs.
If MPC is in the list pick it and put a checkmark in the "Always use the selected program to open this kind of file" option. Press OK.
If MPC isn't in the list use the Browse button and go to where you have MPC installed. Select the MPC program. Back at the Open With dialog put a checkmark in the "Always use the selected program to open this kind of file" option. Press OK. -
I think the MTS file you are refering to has PAFF. If I remember correctly, the regular version of CoreAVC doesn't support PAFF, you need the pro version (and a recent one I believe). KMPlayer's built int AVC decoder doesn't support PAFF.
Also, be sure some other AVC decoder isn't decoding the video (I don't know any others that support PAFF). You can use GSpot to determine what codec is being used. -
Thank you for your help. I had trouble downloading coreavc-- my firewall was on-
My problems with Media Player Classic and Microsoft player was that I had ffdshow loaded- once removed-- all is well
Now, Sony Picture Motion Browser does not work with Haalii running! I remove Haalii- it works
on another computer- with coreavc 1.3-without haalii-all works!?!
How do i display SRT & SUB subtitles on Media Player Classic
By alih786 in forum SubtitleReplies: 11Last Post: 21st Jun 2020, 03:29 -
MP4 Videos Shaky & Distored in Media Player Classic 1.5.3.3705
By Nagashi in forum Software PlayingReplies: 1Last Post: 12th Oct 2011, 15:18 -
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 08:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 12:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49
