Results 1 to 13 of 13
    Jun 2007
    South Africa
    which proggie can do this?can anyone help me?
    USA
    You are looking for a 'authoring' program: https://www.videohelp.com/tools/sections/authoring-dvd
    For freeware, there is GUI for dvdauthor that is popular. Payware, maybe TMPGEnc DVD Author.
    And, of course, these MPEGs have to be DVD compliant before you can author them. See 'WHAT IS' DVD to the upper left on this page for the DVD specifications and format.
    Jun 2007
    South Africa
    u see i wanna take a vob file fix it up an convert it straight back to .vob to insert back into the existing dvd structure
    Jun 2007
    South Africa
    what should i do then?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    First, I wouldn't think about editing DVD video. It's an end format.
    But if I had to (with a gun pointed to my head), I'd use vob2mpg to extract the mpg out of the DVD, do my edits, and then reauthor using some of the apps redwudz suggests.
    If you could be a little more specific, and elaborate on "fix it up", maybe we can find a more streamlined process.
    /Mats
    Jun 2007
    South Africa
    well i got the whole dvd on hd,but when i use clonedvd2 to clone it do dvd disc it gives me an error saying that there is an invalid vobu i know it's in VOB_TS_05_3
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    First, try burning it with ImgBurn in build mode.
    If that wont work, run it thru FixVTS, then try ImgBurn again.
    /Mats
    Jun 2007
    South Africa
    ok will try that will keep u up to date,u see when i ripped it with dvd decrypter it inserted dummy sectors beacuse of some scratches,thats why clonedvd is giving me an error
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    For future reference: You'll get more and more accurate help if you give all details in the first post, instead of handing it out piecemeal
    /Mats
  10. Mod Neophyte redwudz's Avatar
    USA
    demonwarrior, What you describe can also be caused by newer DVD copy protections. It may not be a 'scratch' problem if it is a newer DVD with Sony ArCoSS or similar. The solution then is to use RipIt4Me or DVD Fab Decrypter. DVD Decrypter is a useful program, but it can't handle newer protections.
    Unless it really is a scratch problem.
    Jun 2007
    South Africa
    i did use ripit4me
    Jun 2007
    South Africa
    tx guys got it fixed with Fixvts
