On a VCR with PAL-I, if I play a tape recorded in PAL-BG will it affect the video outputs via S-Video/Composite for capturing purposes ?
thanks
PAL I, B, G only affects the tuner not the recording on tape. VHS records Y and C separately. C is the PAL color component. Any PAL tape* should play the same.
*Excluding PAL M and N which are special cases. -
thanks for the info.
so it means that I get exactly the same picture via S-Video/Composite if the VCR is PAL-I and the tape is PAL-BG, like using a PAL-I VCR, right ? -
Yes. They all use the same luminance scan and subcarrier frequency 4.43MHz. The RF signal may differ for channel frequencies and channel width but baseband (composite/S-Video) should be the same.Originally Posted by abbymat
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47
