Hello all.
I would like to convert some 320x240 4:3 NTSC avi's to DVD. I believe they are DivX3. In your opinion, would it be best to convert them into Half-D1 resolution? If so, is there a freeware application you can recommend that can do this?
I attempted using the Half-D1 setting in FAVC, but it gave me an odd resolution - something like 352x480 (I'm not on my home computer right now, so I'm not sure if this is accurate.) All I know is that I now have considerably large bars on the left and right. Will my DVD players correct this to full screen automatically? I thought the conversion would have made it 352 x 240?I know I can convert it to 720x480 with no problem, but wouldn't this further degrade the picture? Thanks for your input.
Results 1 to 11 of 11
-The Mang
352x480 is 1/2 D1 (NTSC). If flagged correctly (4:3) it should look OK on the TV.
I would keep it 352x240 (also a valid NTSC DVD res) if I was you. Resizing should always be avoided if possible.
/Mats -
There can be reasons for resizing to full screen (if you have enough space to use higher bitrates and the picture is worth it): resizing to half-D is uni-dimensional and further resizing it in a player in the other dimension is not the same as bi-dimentional resizing in proper software.
Thank you for your reply. What freeware software can I use to keep it at 352 x 240 and also not getting too complicated?Originally Posted by mats.hogberg
Thank you too Alex_ander-The Mang -
Don't know, as I rarely do AVI to DVD, and when I do, even more rarely use all-in-one converters. Maybe someone else have an idea?
/Mats -
You can just select VCD Resolution in FAVC if it worked out for you. That equates to 352x240.
Do you mean it will convert it to VCD resolution or make it a VCD? The thought did cross my mind. I actually attempted what you said in Avi2DVD last night, but tried to force it as a DVD. The resulting video was located at the upper 1/4 of the screen and was all jarbled. If I do convert it to VCD, wouldn't this really degrade the picture? I haven't played around with VCD's enough to know how good a quality they can be. The last one I made, made the picture look like SLP on VHS.Originally Posted by Mr_Odwin-The Mang
You could make a HI-bitrate VCD (mpeg1) not strictly to the standards, but they are playable on most players and they can keep all the juice from the files you have. I sometimes made VCD's with 1800 bitrate and they looked pretty good and there was no problem playing them on any of three players. ALternatively create them as mpeg2 in the same dimensions and author them as a dvd (320x240 is a valid NTSC dvd ratio) ie with menus etc etc.
They would look jarbled or gumbled if you try 1/2 D1, you need 1/4 D1 (CIF)
they must be pretty old if they're divx3 ?Corned beef is now made to a higher standard than at any time in history.
It will make a dvd and it will be vcd resolution. FAVC makes dvds, not vcds. So, you can still have a menu, chapters, etc.Originally Posted by louv68
Thanks. I'll give it a go at it tonight.Originally Posted by Mr_Odwin-The Mang
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 10:18 -
Issues converting to 320x240 AVI
By 009 in forum Video ConversionReplies: 5Last Post: 14th Jul 2008, 03:23 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
