I have looked all over and it seems that I am the only one experiencing this problem. Perhaps someone has an idea about what is causing the programme, with the AUTOFIT option enabled, to create an image that is approximately 250MB too large to burn on a DVD5 disc.
I have tried different source material so it would seem unlikely that it is some defect with the AVI's. Also, I unistalled and re-installed the programme (as well as updated .NET) with no change.
The only workaround so far is running the product through DVDShrink to get it down just that little bit more so I can burn it.
Thanks for any assistance!
Danno
log file removed by moderators == re: reference to warez
please see rules regarding posting and/or warez -- as in your attached txt file //
not allowed here -- since it is your first post -- ill remove the txt file / log file and you can repost it making necessary changes ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Sorry - my apologies...
The log file follows:
svcd2dvdlog-20070813195651.txt -
I have sent you a test build via PM. Can you give it a try and post your log again please?
Hi ChrissyBoy,
...I guess you lowered the bitrate? That definitely fixed the problem. Of course it's a Gig or so short of filling the disc, so presumably this is just a test?
The new log file is attached:
svcd2dvdlog-20070815162513.txt -
Indeed - my fault: it was taking into account all 5 of your audio streams... If you grab the latest version from the website, i have made a fix.
Brilliant! That seems to fill out the disc fairly well now.
Thanks for the help, CB! I look forward to the ongoing evolution of the software...
DB -
Thanks for the initial headup!
Autofit not working
By 803082227 in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 30th Oct 2009, 03:57 -
SVCD2DVD Autofit issues
By spyro1981 in forum Newbie / General discussionsReplies: 0Last Post: 12th Sep 2009, 05:15 -
Can we override size that is used in AutoFit ?
By madusmacus in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th May 2008, 15:03 -
AutoFit Issue
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Feb 2008, 16:19 -
No Autofit
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Sep 2007, 04:01
