Is it possible to create a dvd-video which can be played in a standard DVD player, and mounted on a Mac as an HFS filesystem. There is a Mac binary I need to include which will not run unless it has the correct HFS attribute.
I tried this command, but it didn't play right in dvd players.Code:mkisofs -dvd-video -hfs --osx-hfs --macbin -V MYTITLE -o image.iso ./mydata
	You may get better answers in the Mac forum. Moving you.
 And welcome to our forums.
	Burnz will do this for you. If you burn as HFS+, it will include all "lower" filesystems (including UDF). So make your folder structure correct for the DVD and add a folder inside of which you place your Mac app.
 VIDEO_TS
 AUDIO_TS
 MYAPP_IN_HERE
 Place all three of the above folders inside of a folder named for your DVD, then drop THAT folder onto Burnz. Launch Burnz first to configure it properly and then the previous instructions should work for you. Let us know how it goes.
 Look here: http://www.thinkertons.com/
	Will Burnz sort and pad the DVD-video files to make it compatible with DVD players? I downloaded the trial, and the format setting for HFS+ seemed to mention everything but UDF and video. Is there a way to burn [to] images with Burnz? I don't have a DVD burner in the Mac.
	If your file structure is correct (it's been "authored" correctly with the VIDEO_TS folder and all the required files are present therein), then the disc that results (from the Burnz burn) will play in your DVD player (assuming the media you choose is proper for your DVD player). The disc will also contain the HFS+ file system so Mac apps will run if you put the disc in your Mac.
 Burnz will burn disc images to disc but your requirements (of the disc being both UDF and HFS+) are now the responsibility of the app that creates the disc image. OSX doesn't have anything "built-in" and Burnz doesn't create disc images; it just burns folders and disc images to disc.
 Solution: Buy an external DVD burner. Shouldn't be more than $80 if you buy a case and a drive and assemble them yourself.
  Hybrid on mac,..By Selur in forum MacReplies: 72Last Post: 7th May 2012, 01:47
  Need Help with formatting to HFS+ on Windows Pc Using TransmacBy Cornholio77 in forum Media Center PC / MediaCentersReplies: 9Last Post: 26th Jan 2012, 22:46
  Need Help with formatting to HFS+ on Windows Pc Using TransmacBy Cornholio77 in forum Video ConversionReplies: 1Last Post: 17th Jan 2012, 07:26
  Mac HFS to Windows NTFS - how?By jeanpave in forum ComputerReplies: 7Last Post: 16th Nov 2010, 21:34
  what hybrid cars should beBy deadrats in forum Off topicReplies: 0Last Post: 2nd Mar 2010, 19:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
