I hope someone can point me in the right direction. If I right click any .AVI files, select properties and click the summary tab it simply shows "Summary properties are unavailable for the selected source" instead of the usual details about resolution, bit rate, codec etc (in the advanced view that is)
The tab works fine for all other file types (jpg, mpeg, wmv) but with AVI I get nothing.
I know the information is still embedded in the file because if I connect from another XP machine on my LAN to exactly the same file on this PC I can see the Summary details with no problem.
Might have come from installing PowerDirector 6 - read something about it being a registry fix for undeletable files, but all my avis are FINE and i liked using the properties info for speed rather than GSpotting it.
Is there a fix? I installed the WMP10 runtime again as i saw an app install 9 but that didnt work...
"Youth is wasted on the young."
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 21:45 -
Where is the MPEG-2 selection in the summary tab To Target Setting
By RL in forum ffmpegX general discussionReplies: 3Last Post: 31st Jan 2011, 16:42 -
summary tab is missing on a single avi-not a system issue!
By extent in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2010, 17:14 -
AVI video properties missing
By Ayeohn in forum DVD RippingReplies: 3Last Post: 19th Dec 2009, 04:58 -
The Summary tab on a Windows XP video file Properties page is missing!
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 18th Oct 2008, 23:11
