was trying to convert a divX movie to mpg with TMPGEnc 2.02 (the last one) so I could watch it on my DVD and all I've got was sound and a black screen, I couldn't have done anything wrong....I think it's just that because the file I was trying to convert is compressed to much....cause usually a movie takes about 600-700 Mb in divX, this one was only 300 Mb...
what do I do to make tmpgenc convert movies like that...?
please help guys !!!!!![]()
well there are a few things that could be causing it. Does media player play the file? You may need another codec, some movies use a proprietory codec such as smr. Do you have the latest divx codec?
It really does sound more like you need a codec. -
No Media Player doesn't play it, it does put can hear only the sound...non of the players have it play it. have both divXs 3 and 4 and I convert other divx movie to mpg and they work perfectly
I just noticed that the movie that I can't convert is in 20 fps (frame per second) and the ones I converted before without problems is in 29 fps -
Roma, tigerwolf gave you your answer, you have is an smr movie. go to the tools section and get the codec.
LOL so many newbies dont even know when they have been helped.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
