hi everyone, I have a movie i downloaded in AVI format. At the beginning of the encoding in TMPGEnc i stopped it because i seen kind of the words are not in english. Is that the subtitles and how can i convert it to english? Does it have to be done before or after the encoding to DVD MPEG-2 format? Is there guides for converting a language subtitle to english?
Results 1 to 11 of 11
are the subtitles in the picture? or do you have an external subtile file?
The words are in the bottom of the picture.Originally Posted by Baldrick
Then if there is no separate subtitle file, the subs may be 'burned' into the video and there isn't much you could do to fix it.
I do have a question. Is there a way to convert it? What if i follow a subtitle guide on doom9? I am not sure if there guides are converting subtitles.Originally Posted by redwudz
To convert the subtitles you would have to get get them into a text form - .srt is the simplest - then translate the text to whatever language you require, then put them back into the disc. Translation can be automated somewhat through the likes of bablefish, but direct translation usually misses the subtly of language often gives unintentionally humorous results.
Read my blog here.
guns1inger, Is there any guides to do that the translate? what about the subtitle guides on doom9?Originally Posted by guns1inger
I have no idea. I go and find English subtitles on the few occasions that I have needed them. translation is basically being able to read it one language and write it in another. If you don't know the language it is in well enough to translate it to another language then you are pretty much out of luck. If you want to try babelfish then go here : http://babelfish.altavista.digital.com/babelfish/tr
If you have compatible subs, open them in Suntitle Workshop, copy each line, one at a time, into Babelfish, translate it, and use the translation to replace the original line.Read my blog here.
I have no clue want to do. When i start encoding the words of the subtitles is at the bottom of the picture. 1, I don't want foreign language. 2, I want it to be written in pure english.Originally Posted by guns1inger
As was pointed out at the beginning of this thread, if you have no subtitle file then the subs are most likely burned into the video. If this is the case then there is nothing you can do about it. You can't get them out, you can't change them. All you can really do is cut them off and try to find English subtitles instead.
Read my blog here.
There are many sites that archive subtitles for movies and even TV shows.Originally Posted by guns1inger
http://www.opensubtitles.org/ is one of the more comprehensive.
If you can find a matching subtitle you can then format it so that it covers the existing ones -- I had a Japanese movie with Chinese subtitles burnt in and did that with English.
For instance, instead of the usual transparent background, use a dark shade or even black to cover the old subtitles.
For a DVD video, use Subtitle Creator to format.
I find Subtitle Workshop easiest to edit and adjust timing of text subtitles.
mp4box and non-English subtitle
By ngngokkiu in forum SubtitleReplies: 1Last Post: 10th Mar 2012, 05:37 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 10:41 -
Converting subtitle
By rotembal in forum SubtitleReplies: 9Last Post: 28th Apr 2009, 19:45 -
Adding English subtitle to french film?
By viruss3 in forum Authoring (DVD)Replies: 3Last Post: 23rd Apr 2008, 15:03 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
