    Oct 2005
    Maestro will not accept .chp import chapter list created by ChapterXtractor (error is about framerates not matching). I'm converting PAL to NTSC using the DGPulldown method and CCE 2.67...
    I made sure I changed timecode in CCE before re-encoding to 00:00:00:00 and it still wouldn't accept the .chp list. I searched and couldn't find solution. Can someone help? Thanks.
  2. Member Cornucopia's Avatar
    Could be a difference between drop frame designation ("00:00:00;02") vs. non-drop frame ("00:00:00:02"). They have to match.
    Oct 2005
    So prior to re-encoding, I should CCE set timecode to "00:00:00;02" (note: semi-colon) to indicate drop frame? Or... ?
