hi all i have downloaded a hd movie for my xbox360 but it is 7 gig is there a way to split it so can fit on 2 dvdrs? tia
hd movie? could you please give us a bit more information about the format. A wmv-hd file?
You can use Windows File Editor that is included in Windows Media Encoder. Or try asfbin or movica.
I used asfbin the one time I needed to do this and it worked fine.
I am not an Xbox360 owner, but I think the reason people are using WMV is that the Xbox360 doesn't support H.264/X.264, which is what people usually put in the MKV container. If I'm wrong, someone will hopefully speak up and say so. -
cheers m8 for all the info so how would i play a mkv file on my dvd player by converting it?tia
why does 3D movie shows up in split screen on my 3D TV
By greenmetal in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 04:08 -
How can I split 10 GB divx movie into 4 parts?
By andy99 in forum EditingReplies: 3Last Post: 2nd Oct 2010, 16:05 -
Split movie and subtitles
By andreltr in forum SubtitleReplies: 2Last Post: 18th May 2009, 08:16 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 10:54 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 21:21
