i have a movie that i can only play with vlc media player. I am trying to put it on to a DVD so i can play it on my home DVD Player. So far i am struggling with this.
Is there any one who knows how to do this?
				Results 1 to 13 of 13
	ConvertXtoDVD or FAVC will be able to do it. You may need the Haali Media Splitter for FAVC, or FFDShow. Read my blog here.
	what i did was:
 -opened ConvertXtoDVD.
 -i clicked on add video file and then opened my file.
 -i than clicked convert. (it says 3 hours remaining).
 Is this burning onto my blank DVD disc now?
	No, it's reencoding your mp4 video into a DVD compliant format. The actual burning process should be around 20 minutes or less (depending on your DVD writers specs) once the video and audio has been reencoded and authored.Originally Posted by patrick_jimmy
 /Mats
	me too, i am gonna need to do that too shortly. Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	Read my blog here.
	I have done what you said. It played perfectly on the computer but
 my home DVD player can't read the disc. Why did this happen and is there a way to fix it?
	Allok sucks, the last 7 mins of my 42:30 min AVI were completely out sync
 go figgur
 PS
 Did I say that it was a MP4 file that i tried to convert to AVI? Dunno if that matters or not. I ended up with with a file that had video of 42:30 and audio 41:05 long. The audio length was what was reported to the system. all players, (VLC, BSplayer, Vdub etc) WinExplorer, my tooltips etc. all said it was 42.30
 Also, Allok takes about 10 percent longer than playtime to convert.
 However Allok batch-converted the 230 MOVs of my lonelygirl15 collection without much fuss.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	VLC can transcode about any video that it can play fairly quickly, although it may result in a lower quality of video.
 1. Click File >> Open File
 2. Choose the file to convert
 3. Check Stream/Save
 4. Click Settings
 5. Check File
 6. Choose MPEG PS
 7. Check Video codec and choose mp2v
 8. Check Audio codec and choose mpga
 9. Choose bitrates close to the bitrates of the original video
 10. Click OK
	Fine up to this point. Source file bitrate and dest file bitrate are in no way related.Originally Posted by jk318
 Take a DivX with AC3 audio, total 1000 kbps, 448 kbps AC3 audio, 552 kbps video. An mpg video at that bitrate will be completely unwatchable. Of course depending on resolution and other parameters, but no less than 4000 kbps m2v would be my recommendation.
 /Mats
  Putting Together Movie ClipsBy SeaBird in forum EditingReplies: 1Last Post: 24th Mar 2012, 12:31
  putting dvd files (VOB) from dvd and using in windows live movie makerBy emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 07:58
  DVDFABHD putting DVDFAB.com logo on movieBy MCnDaHouse in forum Blu-ray RippingReplies: 7Last Post: 28th Apr 2011, 20:55
  Putting subtitles on MP4 files?By Cooperdk in forum SubtitleReplies: 0Last Post: 6th Dec 2010, 07:09
  Putting More Than One Movie On A DVDBy swordsman in forum Authoring (DVD)Replies: 1Last Post: 19th Sep 2007, 13:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
