how do i fix this?there were some scratches on the source,the source was Tears of the Sun,i need to fix this because i cant cut it with clonedvd or nero
	Well it's pretty well shot in the behind with that damage .
 If you want to recover it , you might want to take it to your local video hire center , they should be able to clean it up for a couple of dollars .
 Or a product called wipeout , from england ... dose that remove scratches or what ... brilliant stuff , repair 300+ disc's before bottle is empty .
 About as far as you can go would be for now is to use the last version of dvddecrypter to rip to folder , and in the options , set it to ignore read errors .
 There's further to go if a new disc is ever to play properly , such as repair the damaged sections in files , before reauthoring can take place .
  VirtualDub Error Message - Video Compression ErrorBy HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18
  Error Message?By mikehr in forum ffmpegX general discussionReplies: 2Last Post: 8th Oct 2007, 01:22
  Get many error messages, AviSynth error message and meGUI errorBy MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
  Error MessageBy Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 13:45
  Error message "CMOS checksum error - Default loaded"By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
