Hi There...
Ive been using avi2dvd for a while now, and it's the first time ive come across this problem.
Basically, when converting an avi file to dvd the finished DVD plays no audio at all, just video.
This problem only occurs with a particular avi file im trying to convert, other avi files convert fine.
My DVD player is not the problem as the audio doesn't play on my pc too.
Here is some audio info on the avi file im trying to convert taken from GSpot:
Audio
Codec: 0x0055 MPEG-1 Layer 3
Info: 44100Hz 96 kb/s , Monophonic
Start of BeSweet log:
BeSweet v1.5b31 by DSPguru.
Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net>
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using AC3enc.dll v1.20 (Feb 18 2004) by Fabrice Bellard (http://ffmpeg.org).
Manual Dynamic-Compression algorithm by LigH (author of WaveBooster).
Logging start : 07/27/07 , 01:40:01.
C:\Program Files\Avi2Dvd\Programs\BeSweet\BeSweet.exe -core( -input C:\Howl\Avi2dvd_temp\Fixed_Audio01.mp3 -output C:\Howl\Avi2dvd_temp\AudioStream 1 MP3 1CH.ac3 -logfile C:\Howl\Avi2dvd_temp\BeSweet_AudioStream 1 MP3 1CH.ac3.txt ) -ac3enc( -b 192 ) -boost( /b=1 /l=0.95 ) -shibatch( --rate 48000 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : C:\Howl\Avi2dvd_temp\Fixed_Audio01.mp3
[00:00:00:000] | Output: C:\Howl\Avi2dvd_temp\AudioStream 1 MP3 1CH.ac3
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] +------ Shibatch -----
[00:00:00:000] | Source Sample-Rate: 32.0KHz
[00:00:00:000] | Dest. Sample-Rate: 48.0KHz
[00:00:00:000] | Attenuation : 0.0db
[00:00:00:000] +-------- BOOST ------
[00:00:00:000] | Algorithm by : LigH
[00:00:00:000] | Boost Factor : 1.0
[00:00:00:000] | Limit Factor : 0.95
[00:00:00:000] +------- AC3ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | AC3 bitrate : 192
[00:00:00:000] | Channels Mode : 2.0
[00:00:00:000] | Error Protection: Yes
[00:00:00:000] +---------------------
[00:00:00:206] Stream error : Sync found after 25 bytes
[00:00:00:320] Stream error : Sync found after 277 bytes
[00:00:00:428] Stream error : Sync found after 95 bytes
[00:00:00:552] Stream error : Sync found after 40 bytes
[00:00:00:650] Stream error : Sync found after 31 bytes
[00:00:00:712] Stream error : Sync found after 207 bytes
[00:00:00:748] Stream error : Sync found after 47 bytes
[00:00:01:301] Stream error : Sync found after 180 bytes
[00:00:01:337] Stream error : Sync found after 83 bytes
[00:00:01:399] Stream error : Sync found after 96 bytes
[00:00:01:622] Stream error : Sync found after 99 bytes
......................^The "Stream error : Sync found after" is then repated many more times.
Any advice related with this issue would be very helpful.
Thanks.
Results 1 to 1 of 1
Any Ways around Only an Audio Output TV?
By Jimmy058910 in forum Capturing and VCRReplies: 12Last Post: 8th Oct 2008, 14:46 -
DVD player audio output question
By Des in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Feb 2008, 12:20 -
Low Audio Output
By house141 in forum MacReplies: 6Last Post: 17th Jan 2008, 23:16 -
No HDMI audio output
By tcheema in forum DVB / IPTVReplies: 2Last Post: 11th Jan 2008, 22:00 -
how do i choose the right audio track going from avi to dvd output?
By kenzo69 in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2007, 19:36
