    I need to make a DVD that has additional content that can be read on a PC. It also needs to play on a DVD player. I realize that the PC content won't be accessible on the player. My question is: do I simply copy the Video_TS folder onto the DVD along with the PC files? I know that nothing goes in the Video_TS folder except the video. Can the Video_TS folder and its contents be copied as any other files or is there a special way these files are written? what about lead-in, lead-out etc.?
    Apr 2004
    Miskatonic U
    Create a new folder at the same level as the Video_TS folder and put your content in there. You can also put content in the root of the disc, such as autoplay files. Use Imgburn to burn the results. Nothing special needs to be done to cater for this.
    Read my blog here.
    Use the Build mode I aasume. Should I select ISO9660+Joliet+UFF file system?
    Apr 2004
    Miskatonic U
    Select the Video_TS folder first, and Imburn will know it is a DVD Video disc and set everything up accordingly. Then add you additional folders and burn.
    Read my blog here.
