I have a copy of monsters inc which goes slightly out of sync (about 1-2s) during each CD.
I've used TMPEnc to do a multiplex and a re-burn on 4x, and it is the same. I've also tried to de-multiplex and re-multiplex the audio and video together. It makes no difference.
Info suggests if the audio is out of sync, export it to goldwave and insert a silence. However, the audio does not start going out of sync until 5 or so minuntes into the film.
Is there anything else I can try?
It generally plays ok on the PC fine. On my Minato G1 it has the sync problems. On my mates Dansai it does the same.
Any ideas?
Thanks as always in advance.
Results 1 to 1 of 1
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
