I ripped a dvd that was episodes, so I used AutoGK to created a series of avi's. I want to use VirtualDub to join them into one avi, but the bitrate differs from one avi to the other.
I suppose I have to use a bitrate calculator & figure out what size the avi's have to be to so AutoGK will set the same bitrate in each.
I'm worried that the 1mb size change allowed in AutoGK will be too coarse to get the exact same bitrate. Is there a bitrate fudge factor in VirtualDub in case the bitrates aren't exactly the same? Is there an easier way of doing it?
VirtualDub is the very best way to join AVI files. Its very easy and very fast.
1. Load First File
2. Append Load Second, Third, Fourth, ... Files
3. Change The Video Encoding Option To Source Copy (Direct Copy, Something Like That)
4. Default Audio Settings Are Fine
5. Save As... -
How can the framerate differs if you ripped the episodes from the same DVD...
Was the DVD both PAL and NTSC hmmmmm
EDIT: sorry did you mean problem with differing bitrates
stars.... -
I join VBR files of different bitrates all the time with VirtualDub. I'm not sure if it works with CBR files of different bitrates though.
<edit>
I just checked: CBR files of differing bitrates work fine too. With VirtualDub, VirtualDubMPEG2, and VirtualDubMod. -
Yeah, it's nothing to do with differing video bitrates. Audio bitrates, maybe. If so, create the audio as CBR with all the same bitrate. And, of course, the resolutions will all have to be the same.
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 15:44 -
Low bitrates with avi.NET
By DeathKing in forum Video ConversionReplies: 5Last Post: 11th Apr 2008, 03:28 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 22:00
